yay ive got me a turbo engine!
Leonard
, Aug 07 2005 09:34 PM
17 replies to this topic
Posted 07 August 2005 - 09:34 PM
ive just got a turbo engine from a mate, but it needs rebuilding. i got the whole engine, and all manifolds, carb dizzy, turbo etc for the bargain price of £60.
trouble is, the end of the crank, on the taper where the flywheel fits is a fairly chewed up. can this be built up and reground?
Posted 07 August 2005 - 10:07 PM
woo nice one not bad
ne chance he got anymore :erm:
Posted 08 August 2005 - 09:30 AM
i dont think so leonard, i believe a new crank is in order, any pics? if it is repairable though i would still get a new crank, its not worth doing a half-arsed job
Posted 08 August 2005 - 09:32 AM
The crank will be beyond repair if the taper is damaged. For every thou removed from the taper I believe it moves the flywheel about 4thou closer to the engine. Not good. (don't quote me on those figures, but I know the flywheel moves closer to the engine very quickly)
The best thing to do is spend the money you've saved on a new crank
Posted 08 August 2005 - 11:36 AM
Yep, there was nothing special about the turbo crank that makes it worth saving.
Just get another one.
Wil
Wil
Posted 08 August 2005 - 07:32 PM
i thought it might be hard to grind a taper. a new crank would be worthwhile i think, thanks for the replies
Posted 08 August 2005 - 10:12 PM
Keep your eye on ebay, new cranks sell for around £150 which is dam cheap :cheese:
Posted 09 August 2005 - 10:32 AM
Just try and find a standard low mileage 1275 engine form a Metro and use the crank form that. Get down to the scrappy ! lol
Phil.
Phil.
Posted 09 August 2005 - 12:46 PM
I thought the proper turbo crank was ntirided to make it stronger?
But, in fact, it's cool to use a normal 1275 crank? That's pretty sweet - I've been keeping my eyes open for a genuine turbo crank on eBay for ages, as a spare. But if a standard 1275 is good to go, then I can relax :grin:
Posted 09 August 2005 - 01:43 PM
If you're lucky you'll find a 6581 crank, this is the proper Turbo crank and they do seem to be a lot harder wearing than the standard A+ 6232 items, though somewhat rarer.
Nitriding a crank will not make it stronger, it just gives it a better surface hardness so they last longer before regrinding is needed.
At the end of the day it's revs which kill a crank, and on most Turbo motors you'll find than max power is made below 6,500 in which case using a standard crank isn't really an issue.
Phil. :grin:
Phil. :grin:
Posted 09 August 2005 - 09:50 PM
MiniSport selling off the CAM6232 cranks with bearings for £150, though bearings will be the standard ones.
http://www.minisport...ft-product.html
The thing with a new crank is that you know that it has not been abused and will have standard bearing sizes all round. A reground item could set you back this much outright
Posted 10 August 2005 - 05:55 PM
Deleted. Ignore this post
Was wrong item :nugget:
Posted 10 August 2005 - 06:35 PM
minispeed are doing ni-tempered reground cranks for £85. i'll go for one of them. I'm gonna fit the mirage T2 kit, as the T3 ive got has a lot of slack in the bearings, and is a bit of a monster for a 1.3litre engine. anyone got a second hand kit? also, how well would an sw5 cam work in a turbo, as im after plenty of torque
Posted 15 August 2005 - 08:19 PM
ive just split the engine from the box, and the crank is a 6581. its a shame its knackered. the pistons dont have much slap in the bores, so ill just put new rings on, as the standard pistons are supposed to be good. if the compression ratio is lowered by opening the combustion chambers in the head, will the standard pistons be ok for more boost?
Posted 16 August 2005 - 03:33 PM
i have a good 1275 crank you can have for a tenner im only down the road as well
