Dial Test Indicator
15 replies to this topic
#1 Pooky
Pooky
  • 5,691 posts
Posted 20 January 2009 - 03:32 PM
Looking to buy a DTI gauge to time my cam and add another tool to the shed.
Should I get imperial or metric? :)
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 20 January 2009 - 03:46 PM
does not really matter, depends what you're more comfortable working with...
#3 Pooky
Pooky
  • 5,691 posts
Posted 20 January 2009 - 03:50 PM
Ok thanks GW :) That would be metric then!
What would most instructions be written in? instructions in Haynes, cam manufacturer etc
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 20 January 2009 - 03:54 PM
Must admit I use a DTI for very few things...
Only when building an engine, useful for doing cam timing, compression ratio calcs that's about it, pretty much everything else can be done with feelers.
When doing cam timing the unit of measurement is not really relevant, just the difference.
Edited by GuessWorks.co.uk, 20 January 2009 - 03:56 PM.
#5 Pooky
Pooky
  • 5,691 posts
Posted 20 January 2009 - 03:58 PM
I know I won't use it very often but will need it when timing the cam in my new engine :)
Thanks again GW
#6 mike.
mike.
  • 6,176 posts
Posted 20 January 2009 - 04:52 PM
I need to buy one of these too if i want to fit a new cam in my new engine, thats probably the only time it'll get used though!
#7 icklemini
icklemini
  • 2,982 posts
Posted 22 January 2009 - 10:09 PM
very usefull bits of kit..
Can use it for checking endfloat (cam and crank) , cam timing, cam profiling, flywheel runouts, brake disk run outs, finding TDC, checking for bent cams/cranks&rods
#8 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,145 posts
  • Name: Sean
Posted 22 January 2009 - 10:23 PM
If you want a dti, check out chester uk, they do a nice range of imported tools
Theres a DTi with stand for £20!!!
#9 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 23 January 2009 - 01:16 AM
I'd suggest an imperial DTI, or one with both scales. Most of the time when using one the scale is irrelevant because all you are doing is finding zero. The few times you do use it for important measurements (end float on the crank for example) it's almost always going to be for something specified in thou by Rover and things like thrust washers are normally defined in thou and only sometimes in both scales.
#10 Pooky
Pooky
  • 5,691 posts
Posted 23 January 2009 - 10:19 AM
Ok, I'll go imperial then
Will this one be ok? eBay might be cheap and nasty...
only one I could find on Chester UK was this one for £32 Chester UK
Oh I've found the vernier 0-3" gauge for £20 on the same page, does this have a magnetic base? Doesn't look as manoeuvrable as the eBay ones...
Can anyone recommend any others?
Edited by Pooky, 23 January 2009 - 10:22 AM.
#11 mike.
mike.
  • 6,176 posts
Posted 23 January 2009 - 10:24 AM
I might buy one of those £14 ones. Is 0-1" right?
#12 Shifty
Shifty
  • 13,145 posts
  • Name: Sean
Posted 23 January 2009 - 05:26 PM
The chester website is poo!!!
Give them a bell, its in the catalogue, a dti guage with magnetic stand in a blow moulded case.
#13 minivanman
minivanman
  • 3,454 posts
Posted 23 January 2009 - 10:33 PM
I've got one like that pooky, its cheap and cheerful, but it does the job. Like icklemini says, they are very useful, not just for engine building!
#14 icklemini
icklemini
  • 2,982 posts
Posted 24 January 2009 - 12:15 AM
you got one in the end tom?? :)
#15 minivanman
minivanman
  • 3,454 posts
Posted 24 January 2009 - 12:25 AM
Yup, cams all in and sorted Dave. I need to check the run out on the discs as well while i'm thinking about it :)
