1275 Mini Stuttering When Accelerating
22 replies to this topic
#1 masserator
masserator
  • 113 posts
Posted 23 January 2009 - 01:32 PM
i have a 1275 1993 mini which stutters when accelerating any ideas as to how to cure this?
#2 the.stroker
the.stroker
    TMF Admin
  • 4,348 posts
  • Name: Dan
Posted 23 January 2009 - 01:35 PM
if its injection:
clogged fuel filter
dirty airfilter,try driving it up and down the road without the air fiter
black pipe has come off ecu
red pipe to throtle body,kinked or come of or even broken completely.
could also be a loose h.t lead????
can you be more specific
#3 masserator
masserator
  • 113 posts
Posted 23 January 2009 - 01:41 PM
its actually a carb mini
when accelerating in 2nd gear it will get up to 30 then not speed up any more and the engine makes a 'bubbling' sound
although if i just rev it it doesnt seam to have any problems. i have also noticed that having the choke in or out has no effect and has to turn over a couple of time before it fires
#4 huntface
huntface
  • 711 posts
  • Local Club: LSMOC
Posted 23 January 2009 - 01:42 PM
Carbon fouled plugs as a result of a too rich mixture?
I know mine use to stutter quite a bit until i cleaned the plugs up and adjusted the mixture.
#5 masserator
masserator
  • 113 posts
Posted 23 January 2009 - 01:44 PM
how do i adjust the mixture
#6 huntface
huntface
  • 711 posts
  • Local Club: LSMOC
Posted 23 January 2009 - 01:49 PM
Have you got a haynes manual to hand? That'll be able to expalin it better than I can. There's a brass nut on the right hand side of the carb that adjusts the mixture
Be careful though, because a slight turn of the nut equals a big change in the mixture
http://drcwww.uvt.nl...eup/hs2idle.gif
Edited by huntface, 23 January 2009 - 01:52 PM.
#7 SurreySprite
SurreySprite
  • 162 posts
  • Local Club: LSMOC
Posted 23 January 2009 - 02:21 PM
I've got a 1994 Sprite which has a 1275 Carb. May be problems with damp? Have you checked the condition of your ht leads and cap?
Worth checking your plugs as well.
#8 masserator
masserator
  • 113 posts
Posted 23 January 2009 - 03:11 PM
Have cleaned the plugs and taken off and put back on the leads I have also put in some more oil as that was low but has made no difference
#9 SurreySprite
SurreySprite
  • 162 posts
  • Local Club: LSMOC
Posted 23 January 2009 - 03:16 PM
What were the plugs like before you cleaned them? Maybe a clue to the problem from the state they were in.
#10 masserator
masserator
  • 113 posts
Posted 23 January 2009 - 03:20 PM
they were coated in black soot that came off easily
#11 huntface
huntface
  • 711 posts
  • Local Club: LSMOC
Posted 23 January 2009 - 03:44 PM
It does sound like carbon fouling.
What did you clean the plugs with?
You've got to make sure you get all the crap off the electrodes. Use a squirt of brake cleaner and some wet and dry paper and give them a really good going over. Especially in the gap.
#12 masserator
masserator
  • 113 posts
Posted 23 January 2009 - 04:21 PM
Would it just as easy to get new plugs?
#13 huntface
huntface
  • 711 posts
  • Local Club: LSMOC
Posted 23 January 2009 - 04:50 PM
Well yes.
>_<
#14 masserator
masserator
  • 113 posts
Posted 23 January 2009 - 05:33 PM
#15 masserator
masserator
  • 113 posts
Posted 25 January 2009 - 03:42 PM
Now put new plugs in and no joy:( as I put my foot down it looses power then stalls
Edited by masserator, 25 January 2009 - 03:45 PM.
