1275 Mini Stuttering When Accelerating
#16
Posted 25 January 2009 - 04:01 PM
#17
Posted 25 January 2009 - 04:09 PM
#18
Posted 25 January 2009 - 04:20 PM
Once all the ignition components are known to be good and once the ignition settings are correct you can move on to car adjustments.
On their own, carb adjustments take a while to "go out". It's not very common for carbs to be in tune one day and suddenly be out of whack the next. Ignition components, particularly points, can wear quickly or fail and be OK one day and need attention the next.
#19
Posted 25 January 2009 - 10:37 PM
It has points
Eh? An original 1275cc engined 1993 Mini should have electronic ignition, like all Minis of that era.
The last Minis to have points were the 1992 998cc engined Mini City and Mini Mayfair. Electronic ignition was introduced to all Mini models when the 1275cc engine was used across the board.
The Rover Mini Cooper models had electronic ignition from 1990.
#20
Posted 26 January 2009 - 08:31 AM
air intake pipe had broke and leet dirt into the carb, trapped at the bottom of the needle iirc, but had bent the needle.
this caused the same thing to happen.
worth screwing of the dash pot an checking if anything looks out of place?
hope this helps.
dan
#21
Posted 26 January 2009 - 09:25 AM
warm up the engine, then rotate the distributor VERY slightly. Try not to touch the leads on it though, as they are 40,000volts. I tend to rotate it with a plastic handled screwdriver,as I am a wimp. See if, by turning the dizzy a few degrees either way the revs change. BUT, mark where it is now, in case this is NOT the problem. You then have the original setting to return it to.
Has itg got any WORSE with time (weeks) or is it the same?
#22
Posted 30 January 2009 - 05:08 PM
in the end it was the air filter was too cloged and so no air was getting in in (doh!)
now cleaned the filter and adjusted the points slightly and all is well again:)
my mini is a K reg (says 1993 on v5), is there anywhere online to check if it should be electronic ignition?
#23
Posted 30 January 2009 - 10:01 PM
have now fixed the probem:) thanks all for the help
Put your engine number into this as it will tell you what you should have: -
http://www.guess-wor...ical/engine.htm
If your Mini is a 998cc it will have points, but if it's a post 1992 1275cc engined Mini (as standard), then it would have come with electronic ignition.
