Very High Idle After Re-fitting Carb
15 replies to this topic
#1 abridger1275
abridger1275
  • 26 posts
Posted 24 January 2009 - 09:23 PM
Model:mini1275 rio
Year:1993
well i tried fitting a cone filter this afternoon and had a few issues n what not so i decided to go back to the original set-up of the airbox, but now when i re-fitted the carburettor , without the choke or throttle cables connected and both connections in their closed position the engine is idling at 4000rpm!! i have checked the condition of the needle and it is fine, checked the damper, fine, checked the dashpot oil, fine, butterfly is fine, so now im really stuck, im dreading it being anything worse! i really need the car as it is my daily! any help asap would be greatly recieved!!
Any non-standard parts that might be involved with the problem?
LCB? minispeed inlet manifold
#2 brad88
brad88
  • 349 posts
  • Local Club: minimusmaximus
Posted 24 January 2009 - 09:34 PM
Model:mini1275 rio
Year:1993
what carb is it hif38-44? 44 probably but either way, put on the cables to start with and if its still bad then try adjusting the idle screw which is located at the bottom right of the dashpot looking down on top of it with the airbox off, screw it out (anti-clockwise) and the revs will fall, screw it in (clockwise) and the revs will rise, keep trying until its about right, best to let the car warm a little before doing it aswell, hope that helps, brad :)
Edited by brad88, 24 January 2009 - 09:34 PM.
#3 abridger1275
abridger1275
  • 26 posts
Posted 24 January 2009 - 11:24 PM
Model:mini1275 rio
Year:1993
what carb is it hif38-44? 44 probably but either way, put on the cables to start with and if its still bad then try adjusting the idle screw which is located at the bottom right of the dashpot looking down on top of it with the airbox off, screw it out (anti-clockwise) and the revs will fall, screw it in (clockwise) and the revs will rise, keep trying until its about right, best to let the car warm a little before doing it aswell, hope that helps, brad :-
already tried that, its hif38 and iv wound the idle screw rite out and the butterfly of the carbs like in the shut position its still revving really high, any one else?!
#4 glyn
glyn
  • 637 posts
  • Local Club: leyland mini club
Posted 24 January 2009 - 11:31 PM
is the dash pot on straight the float needs to move inside smoothly :-
#5 abridger1275
abridger1275
  • 26 posts
Posted 24 January 2009 - 11:37 PM
yh the dashpots on fine, its like its doing what it wishes, i literally turn the key and it revs up straight away to 4000rpm i cn lower the revs by semi covering the carb elbow and it sucks reli hard haha, i can rev the engine via the accelerator pedal, just seems like theress no explanataion as to why its revving so bad.
#6 glyn
glyn
  • 637 posts
Posted 24 January 2009 - 11:48 PM
if the air filter is not on it will rev fast u need the air filter on.
#7 abridger1275
abridger1275
  • 26 posts
Posted 24 January 2009 - 11:56 PM
does the same with the airbox on, i was out today for a good 4 hours confused to death!
#8 abridger1275
abridger1275
  • 26 posts
Posted 25 January 2009 - 10:19 AM
sunday morning bump! i need help!!! arrr
#9 insamoufonyx
insamoufonyx
  • 1,633 posts
  • Local Club: NorthSomersetMiniClub.co.uk
Posted 25 January 2009 - 10:30 AM
you sure the dashpot isnt wedged open?, or have you acerdently bent the needle? even the tinyest bend can make a huge difference!
#10 gregster
gregster
  • 46 posts
  • Local Club: no
Posted 25 January 2009 - 10:52 AM
Have you had the cables off ? you may have set the linkages open on the choke/throttle cables
better to have a little play in the cables than setting them tight
#11 Hagar
Hagar
  • 16 posts
Posted 25 January 2009 - 07:33 PM
Is the return spring fitted correctly?
#12 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 25 January 2009 - 07:35 PM
Air leak?
#13 Pauly
Pauly
  • 4,213 posts
Posted 25 January 2009 - 07:39 PM
Would of said air leak aswell.
Paul.
#14 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 25 January 2009 - 08:29 PM
Under what conditions have you guys seen air leaks increase engine speed? The only places I've come across leaks are AFTER the carb. Those leaks have created weak mixtures that typically won't allow the engine to even run unless you pull the choke WAY out.
#15 abridger1275
abridger1275
  • 26 posts
Posted 26 January 2009 - 07:12 AM
iv run with the cables disconnected and the dashpot is on 100% the butterfly isnt stuck open or anything, ive been led to believe by a friend that i could have a vacuum leak after the carburettor?
