Engine Tuning
12 replies to this topic
#1 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 25 January 2009 - 10:19 PM
Ive finally got my 1275 running due to timing issues. Although ive got a carb that was tuned for a 1380 engine. I need to change the needle.
At the moment it won't run without choke, and doesn't run well at all.
The needle at the moment is quite thick, would making it thinner make it run better?
I would much rather just put a needle in it though than mess around with it, what needle would you recomend for a 1275, HIF44 and stage one kit.
#2 FartinMartin
FartinMartin
  • 207 posts
Posted 25 January 2009 - 10:21 PM
BDL or BDR
#3 mini_mad69
mini_mad69
  • 5,417 posts
Posted 25 January 2009 - 10:31 PM
BDL or BDR
Brilliant thanks alot. I will sort one of those out as soon as possible, Is there anything I can do to get it running better for now, because I want to get an MOT before wednesday.
#4 mini_mad69
mini_mad69
  • 5,417 posts
Posted 26 January 2009 - 12:42 AM
BDL or BDR
Mini spares sais the BDL should be used with a 256 degree duration camshaft with standrad filter. Thats not my setup.
#5 Marky Tizz
Marky Tizz
  • 2,434 posts
  • Local Club: LSMOC
Posted 26 January 2009 - 12:54 AM
playing with winsu gives O?7 as the best result, but I dont have the full version so i can't work out the last letter :/
#6 Marky Tizz
Marky Tizz
  • 2,434 posts
  • Local Club: LSMOC
Posted 26 January 2009 - 12:55 AM
had another fiddle, managed to find out it's a OA7. Only quickly checked it out but that gave the best results overall, 0.6% rich throughout, as opposed to 4+% on anything esle.
Hope that helps.
#7 mini_mad69
mini_mad69
  • 5,417 posts
Posted 26 January 2009 - 12:57 AM
Ummm it might help if I knew what those numbers meant, doesnt come up on mini spares.
#8 mini_mad69
mini_mad69
  • 5,417 posts
Posted 26 January 2009 - 12:56 PM
Ok im stuck, I can't get it running nice. I put a carb on from my 998 and it took ages to get running once it did it was rough as anything and kept spitting back throught the carb mouth. Not going to use that carb then.
It drove on the hif44 but needs choke to idle, what do I need to do to the needle to make it idle? shave off the point or nearer the top by the spring. I want to take this car for an MOT tomorrow.
#9 Marky Tizz
Marky Tizz
  • 2,434 posts
  • Local Club: LSMOC
Posted 26 January 2009 - 01:18 PM
Eeeek I'm not sure about profiling needles, try a PM to dklawson? He did a thread a little while ago about profiling needles I think, I'm sure it was him.
As for the OA7 needle, you'd have to do a google, or try www.burlen.co.uk
HTH.
#10 mini_mad69
mini_mad69
  • 5,417 posts
Posted 26 January 2009 - 04:13 PM
Well thank you who have helped. Ive now got it going quite well, I think itll be enough for mr MOT man. 1000 rpm idle and revs very freely. Hopefully its enough,Idealy I need to get it on a CO2 meter but I cant afford one. I got the needle from a scrap carb I found in a friends garage.
I think its a standard 1275 needle, but who knows.
#11 mini_mad69
mini_mad69
  • 5,417 posts
Posted 08 February 2009 - 10:41 PM
BDL or BDR
Will one of those needles work?
It's an SPI engine, running a HIF44 carb, foam air filter, lcb exhaust system. Slightly bigger valves.
Pretty much a stage one 1275 engine.
#12 lrostoke
lrostoke
  • 6,923 posts
Posted 09 February 2009 - 08:00 AM
Minispares stage 1 kit for a 1275 with HIF44 carb comes with a BBW needle
You can tell which needle you have because at the thick end it will be stamped on the side.
#13 mini_mad69
mini_mad69
  • 5,417 posts
Posted 09 February 2009 - 04:35 PM
Thanks i'l order one now.
