After a fallow 18 months i'm starting to get back into my mini project. It's a bit cold out to be welding, so i've been designing stuff instead.
So my rear beam design is as follows:
By NovaNath
3x 1.5" box Ali 6082 extrusion, 1/8" thick
2x1" x1/8 brackets with webs, all welded to the box section
Brackets mounted so that the axis of rotation is parallel to the box sec and the grond (no toe/camber)
Inbored bracket has oversize hole to allow radius arm spindle to be inserted(ooh-er)/removed, and top-hat washer (red) to centralise spindle in bracket.
Now my 'clever' idea is that the top-hat washer can be drilled eccentrically to allow toe in/camber setting (there's a pin to locate the washer and stop it rotating.
I know i'll need a new set of washers for every different setting that i try, but i can 'do the math' to work out the dimensions.
What i was wondering, is, will having the adjustment on the inboard bracket have an impact on the placement of the wheel in the arch?
Anyway, let me know what you think
Nathan
