Welding Sills (mot Advice)
28 replies to this topic
#16 cookie4343
cookie4343
    **Caution: Do Not Feed Alcohol**
  • 2,257 posts
  • Local Club: CV1 Mini's
Posted 02 February 2009 - 01:05 AM
Hi
i am currently restoring my 1960 mini minor. The new floor panels and outer sills on these are one part, and i am currently just doing the Right hand side.
Anyway, on the original car, it looks like the sill and door step were roller welded together, the spotwelds being 5 or 6 mm aprt from eachother.
I have plug welded the new panels together (with my MIG welder) at approximately 20mm apart between the welds. However, my plug welds are bigger in diameter then the original spotwelds.
Is this OK for an MOT, or do i need to carry out more welding?
John
Mine went thrue its M.O.T like this sills spot welded on then seam sealed and waxoiled M.O.T tester said nothing so i would think your be ok.
#17 Minid
Minid
  • 76 posts
Posted 02 February 2009 - 07:52 PM
As ive always understood-
Replacement panels welded as originals
Patches or repair panel seam welded
That is until another mot man said to me the other week seam weld everthing, so i was going to ask if it had changed recently?
But youve all answered this for me.
Some years ago i did have mot man ask to see welds after it had been painted-so i now take pictures.(probably wanted to know what a good weld should look like)
Cheers.
#18 In-a-mini
In-a-mini
  • 831 posts
  • Local Club: smag (southend mini action group)
Posted 02 February 2009 - 08:42 PM
I restore cars and if i were to leave all my repair welds there or seam weld everything i wouldn't be in a job for long. and the car would way twice what it should lol
#19 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 02 February 2009 - 08:49 PM
Quite simple, if you're fitting replacement factory spec panels, then fit them same as they would be from the factory. If you were fitting oversills then they should be seam welded, but I don't think you will be, somehow!
#20 mk=john
mk=john
  • 1,167 posts
  • Local Club: Milton Keynes Mini Club, Mini Cooper Register
Posted 02 February 2009 - 09:51 PM
Hi
So, do you mean you leave your sills spotted? My prep work, including zinc coating the surfaces to be welded is thourough. I have done a neat job, but I just want to be sure this type of welding is enough.
#21 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 02 February 2009 - 10:10 PM
This is how a sill is welded in the factory, and should be on all cars with standard non oversill type sills. This is perfectly good for MOT, same as a brand new car.
#22 midridge2
midridge2
  • 1,794 posts
Posted 02 February 2009 - 10:38 PM
a bit ambigious pete, because a panel was spot welded at the factory does not mean a replacement panel has to be spot or plug welded you can still seam weld, there is a lenght and spacing for seam welds i believe for mot standard. it does not have to be continious.
#23 Saxo-Fiesta-Mini
Saxo-Fiesta-Mini
  • 2,889 posts
  • Local Club: LCMOC
Posted 02 February 2009 - 10:42 PM
lol advice on welding dont start ull never end with a mini theres always more rust unless u replace the lot with fiberglass or carbonfiber
#24 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 02 February 2009 - 11:16 PM
Yes I didn't mean it was the only way, just that if you want to pass an MOT, if it is done to the same standard, it will be fine.
#25 Minid
Minid
  • 76 posts
Posted 03 February 2009 - 07:50 AM
Is there any drawings of where and how mini panels are welded.
Thinking back i remember operators in the factories having sheets with basic instructions??
Just make life easier for dismantle and assembly??
Cheers.
#26 black jack1275
black jack1275
  • 276 posts
Posted 03 February 2009 - 09:04 AM
Have a look at this topic page 3 ;)
http://www.theminifo...showtopic=38927
Edited by black jack1275, 03 February 2009 - 09:05 AM.
#27 midridge2
midridge2
  • 1,794 posts
Posted 03 February 2009 - 11:14 AM
remember if you replace with a wide over sill you will need to fully seam weld as this is not a genuine replacment panel, its classed as a patch.
i am still confused with some people saying the sill flange to door step is not roller welded, all minis up to 1996 that i have replaced the original sills have been roller welded.
because of the roller welds i alway cut under the seam and leave the flange on and seam weld the sill to the 2 flanges (the door step with the old sill flange still on).
#28 SolarB
SolarB
  • 1,387 posts
Posted 03 February 2009 - 01:24 PM
I can not say for the early minis but all i have worked on have has spaced spot welds. And as previously stated the continuous spot welds were only to seal IE tanks and roof panel withing gutter.
The seams down the A pillars and C pillars are also continuously welded.
#29 In-a-mini
In-a-mini
  • 831 posts
Posted 03 February 2009 - 07:20 PM
I did not say they were the only places. as stated it does not aid the strength excessively it is usually to seal!
And all my minis have been pre 1996 and none that i have replaced the sills on have been fully/roller welded some have had closer spaced spotwelds and even have differed side to side but not roller welded. And yes i mean replacing the original sill not one someone else has fitted.
Interesting as it is the topic is going a little of. As peter and others have stated spaced spot welds/plug welds are sufficient and well to mot standard.
Edited by In-a-mini, 03 February 2009 - 07:20 PM.
