Rain/snow Precautions?
Posted 06 February 2009 - 12:11 PM
1992 Mini City E
Posted 06 February 2009 - 12:22 PM
1) Early morning mist, fixed via WD40 (spark plugs, not dizzy).
2) Same as 1 again.
3) Driving through a ford at 50-60mph.
4) Driving through around 5inch (deep) of flooded road at 40-50mph. Then pushed car home.
My suggestion is just take some WD40 with you and maybe stick a marigold on the dizzy to keep it dry.
Posted 06 February 2009 - 12:33 PM
Posted 06 February 2009 - 12:47 PM
I have only ever 4 times been screwed by water on/in my engine.
2) Same as 1 again.
How does WD40 help, and do you mean a rubber glove?
I currently take the dizzy cap off a lot as I remove the rotor arm overnight due to a previous theft attempt.
Posted 06 February 2009 - 12:49 PM
I'd be more worried by the salt, give it a thorough wash when the thaws done. Electronic ignition helps and you can easily make a dizzy sheild out of a bit of plaggy to stick behind the grill. Good, clean, condition leads and wiring should be all you need.
Ok, well I am not sure how to clean the underside except for taking it to a car wash (and I'm not convinced that will do the mini any favours either. I had completely forgotten about the salt and now I'm cross with myself for taking her out in it (I have a sensible skoda which I should probably be using!)
Posted 06 February 2009 - 12:50 PM
I am worried about sticking anything behind the grill because presumably it is a grill for a reason, for cooling/air for the air filter? How much can I block?
Posted 06 February 2009 - 12:56 PM
'n just stick a couple of quid in the jet wash and attack it from all angles underneath and around the wheel arches.
Posted 06 February 2009 - 12:59 PM
another old one is to get a rubber glove cut the tips of the fingers off and put it over the dizzy cap.
Posted 06 February 2009 - 02:51 PM
Wd40 displaces water, spary some on coat the electrics for a bit. Many dissuade from it as it leads to dirt build up. I always keep a can in the car anyway for when I need it. Rather have some dirty engine parts than be stranded with a soggy spark plug.
As for the marigold, yes a rubber glove. Cut off the end of the fingers, fit over dizzy with leads coming out of each finger, then zip tie each finger up.
Job done.
Posted 06 February 2009 - 04:29 PM
Saying that I just use a plastic bin back to cover the coil , dizzy and HT leads, never misses a beat now.
Posted 09 February 2009 - 11:44 PM
http://www.minispare...h...ld&s=Search
Posted 09 February 2009 - 11:49 PM
More than you'd think, the original dizzy shield was only about 8x6 inches.
Jet wash wasn't working because of the cold, will driving through today's rain have done the job?
Posted 09 February 2009 - 11:56 PM
Unlikely as the rain water might contain the remnants of salt off the road.
And try to avoid using WD40 (unless you really have to and then clean it all off afterwards) because it sits on the electrics and attracts all manner of grime, causing even more problems in the long run.
So clean and dry electrics are the best way forward.
Posted 10 February 2009 - 01:26 PM
1. Get a shield to protect the distributor (minimine do nice ones, but most Ministores sell them)
2. Get electronic ignition if you havent got it already.I fitted a MAGNETRONIC set-absolutely brilliant.
3. The marigold trick I have never tried because I would be more concerned about trapping water inside the cap (causing tracking issues) than repelling it. But thats just my opinion! Try it and see if its helpful to you.
Andy
Posted 10 February 2009 - 02:24 PM
