Ford Ka
23 replies to this topic
#16 cooper1275
cooper1275
  • 11 posts
  • Local Club: none but will get around to it
Posted 06 February 2009 - 09:02 PM
my sister bought a 99 ka about 5 years ago and is happy with it. nothing ever goes wrong on it but she did buy a low miles, fully serviced one from a reputable ford dealership that my dad has dealt with all his life so maybe she was lucky?
#17 AndrewJ530
AndrewJ530
  • 1,628 posts
Posted 06 February 2009 - 09:23 PM
My girlfriend used to have one until she was crashed into.
Good on fuel, nippy, similar to a mini without the charm ( :shifty: waits for heckles for the comparison).
Only thing i would worry about is the brakes. They seem to not be very responsive even when fully depressed. Maybe not enough pressure but this happened in all 3 KA's i have driven (girlfriend's and her 2 mates cars).
Don't know much about rust because my girlfriend's was an 04 reg. They do get tappety mind but still run fine.
Overall i'd say they are a good, cheap little run around. Bit noisy because they are tinny but what little car isn't.
Andrew
#18 *Raz*
*Raz*
    PC Hands
  • 4,039 posts
  • Local Club: Brighton
Posted 07 February 2009 - 01:35 PM
I cant stand the old KAs but they have just released the new one, tis quite nice, mainly because it looks nothing like the other one!
#19 mighty mini jack
mighty mini jack
    Mighty Before a Pint
  • 5,095 posts
Posted 07 February 2009 - 05:23 PM
The rear pockets.. they snap :D
*wonders if my uncle ever found out*
#20 sven_2k4
sven_2k4
  • 188 posts
  • Local Club: na
Posted 09 February 2009 - 09:55 AM
A friend of mine has a 4 year old Ka with 17k on the clock.
Failed MOT on
  • both front springs
  • both front spring carriers (bearings at the top)
  • corrosion to the cills
It also started leaking trough the bulkhead on the drivers side.....been to Ford with it twice charged £90 each time for the privalidge and it still leaks!
I'll stick with the mini ta!
#21 midridge2
midridge2
  • 1,794 posts
Posted 14 February 2009 - 12:15 PM
main faults with the ford ka, depending on year.
power steering rack fail.
bottom arm rubbers fail.
very noisy front struts.
front strut top bearing fail.
heater stops giving out hot air.
rear wheel bearing fail.
bit of a delay when you press the brake pedal.
spark plugs rust up and snap off when trying to remove.
tappity engine.
sump rusts and leaks.
sills rust fast.
poor paint ( easy chips)
look at ford ka webforums to see the most common faults.
some one said they are over priced, under £6000, what other cars can you get for that price new?
#22 minidriverfiona
minidriverfiona
  • 169 posts
Posted 14 February 2009 - 06:18 PM
I have one as a courtesy car at the moment while my mini is having some work done, and I do find the brakes are *poop poop*, I passed 2 junctions accidentally!!! Not a patch on a mini anyway.
#23 macfoot
macfoot
  • 561 posts
Posted 14 February 2009 - 08:15 PM
look out for the cam shaft which is a bad point for them too
#24 mattdc2r
mattdc2r
  • 1,296 posts
  • Local Club: Not yet!
Posted 14 February 2009 - 08:26 PM
find yourself a nice green Puma for about £2k instead................................... O_O
Try the for sale section on this very forum. Strange old thing.
