Flat Or Dished Pistons In A 998
Posted 08 February 2009 - 11:15 AM
Thanks in advance
Posted 08 February 2009 - 11:21 AM
Posted 08 February 2009 - 11:32 AM
Posted 08 February 2009 - 11:37 AM
Posted 08 February 2009 - 11:41 AM
Posted 08 February 2009 - 11:42 AM
Posted 08 February 2009 - 11:48 AM
Thanks how do you work out the volumn above the piston? if i have the cc off the head Thanks
Have a search 'n google it's been covered many times. It will be cheaper and easier to alter the head volume than fit new pistons.
Posted 08 February 2009 - 01:27 PM
The numbers that i got of the head is cam4810, 1407 and also BIL is marked on the headno if you have the head from Minisport you should know the CC of each chamber it may well be stamped on the head you then work out the volume above the piston, a bit of maths later and you have your compression, you dont want to go more than 11.1 on a road engine with normal petrol.
Posted 08 February 2009 - 01:32 PM
Posted 08 February 2009 - 01:47 PM
Posted 08 February 2009 - 01:51 PM
If they worked the combustion chambers it would need skimming to restore the original volume.
Posted 08 February 2009 - 02:15 PM
Posted 08 February 2009 - 02:25 PM
Posted 08 February 2009 - 02:34 PM
Maybe give MiniSport a call and they will tell you the size of the cc.
Posted 08 February 2009 - 06:01 PM
Edited by Rosslin Racing, 08 February 2009 - 06:01 PM.
