Clutch
9 replies to this topic
#1 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,737 posts
  • Name: Chris
  • Local Club: None
Posted 08 February 2009 - 12:47 PM
its a 1979 1100 special
the clutch is going and sliping like mad when i accellerate (blokes as work say its because im too fat lol)
but am not sure wether its a verto or non verto clutch that i need i got told that it had something to do with length of a the arm??
heres a pic hope his helps with the diagnoises
YetI
ps i did search and couldnt find anything that helped
#2 atom
atom
  • 239 posts
Posted 08 February 2009 - 12:53 PM
That's a verto, but I can't offer much more help than that :)
#3 L400RAS
L400RAS
  • 2,479 posts
  • Local Club: Lincolnshire Mini Owners Club
Posted 08 February 2009 - 04:51 PM
Hi yeti,
Yes - thats definately a verto setup - short clutch arm, and the slave cylinder is mounted on a seperate bracket off the crankcase.
# i do have a question - at the minute, the pivot for the clutch arm appears to be a hex head bolt? - see picture;
Is this the case, or is it just rusty? - If so, when you do the clutch i would order a proper clevis pin and split pin;
Clevis pin
Now, the bolt may have worn the clutch arm too,
Short clutch arm.
Shame it's the verto clutch - more expensive than the non-vertos..
Ryan
#4 icklemini
icklemini
  • 2,982 posts
Posted 08 February 2009 - 05:06 PM
that plate the slave cylinder is mounted to is also missing the lower bolt that holds it onto the housing and stops it levering up - as it currently is doing...
#5 icklemini
icklemini
  • 2,982 posts
Posted 08 February 2009 - 05:08 PM
looks like it has been bodged with a bolt too (through the arm pivot)... so would imagine the hole in the clutch cover is over-size now...
so to go back to a clevis pin... you'll need a replacement clutchcover too...
#6 tommy13
tommy13
  • 878 posts
Posted 08 February 2009 - 05:12 PM
Are you aware that the slave cylinder bracket is considerably bent and there is a mounting bolt missing which goes through the slot you can just see near the operating arm end. It should screw into the small protrusion on the clutch cover and I think there should be a spacer between bracket and cover.
As mentioned above the arm pivot looks very rusty, if this were stuck or very stiff it could cause clutch slip
#7 icklemini
icklemini
  • 2,982 posts
Posted 08 February 2009 - 05:18 PM
lol - echo!
#8 yeti21586
yeti21586
  • 3,737 posts
  • Name: Chris
  • Local Club: None
Posted 08 February 2009 - 09:10 PM
thanks for the advise
ok its not stiff at all and i wasnt aware of any of the "bodges" on in it.
so in one sentence part from a new clutch what else do i need to get?????
YetI
Edited by yeti21586, 08 February 2009 - 09:10 PM.
#9 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 08 February 2009 - 09:14 PM
a clutch cover because it has been bodged up with a bolt
a bolt and spacer to hold the slave cylinder plate correctly on the clutch cover
and if it needs a new clutch then a vetro one.
dave
#10 yeti21586
yeti21586
  • 3,737 posts
  • Name: Chris
  • Local Club: None
Posted 08 February 2009 - 11:29 PM
cheers dave i have now made a post in the wanted section.
YetI
