Hif Carb Oil Problem
11 replies to this topic
#1 buxvan
buxvan
  • 146 posts
Posted 08 February 2009 - 09:36 PM
evening, my metro 310 van 1275 a plus is great but a problem has started
i top up the dashpot & within 2 days it has emptied.
where is the oil going & is this why the car stalls when i dip the clutch when slowing down?
thanks in advance
#2 icklemini
icklemini
  • 2,982 posts
Posted 08 February 2009 - 10:09 PM
do you remoe the piston rod when topping it up? - try just unscrewing the cap and without removing (only move it to the side) - top up the oil to the top of the inner tube... then screw the cap back on.
#3 buxvan
buxvan
  • 146 posts
Posted 08 February 2009 - 10:53 PM
yes i do remove the piston completely, i thought thats what you were meant to do, what difference will it make if i just move it to the side & then add the oil? thanks for reply.
#4 icklemini
icklemini
  • 2,982 posts
Posted 08 February 2009 - 10:57 PM
when you pull the piston out - more often than not oil gets pulled up with it and escapes past the tube..
owner then thinks "oo wheres that oil gone" - fills it up to the brim.. spends 5 minutes trying to push the piston back in...
then repeat the next time its checked...
#5 buxvan
buxvan
  • 146 posts
Posted 08 February 2009 - 11:12 PM
yes, but if i fill it to the brim & gently refit the piston, wont that mean that the oil level is full? thats what i,ve been doing but the whole thing is empty in 2 days or 100 miles. i still don't understand !!
#6 crizd
crizd
    is not wired up right
  • 187 posts
  • Local Club: None :(
Posted 09 February 2009 - 04:56 PM
I have same problem, my dashpot oil goes somewhere, then I start stalling at junctions, so I top it up, and all fine for a week or so. :S
#7 crizd
crizd
  • 187 posts
Posted 09 February 2009 - 05:19 PM
Could it be the piston damper is leaky? Ive swapped it for another, and still the same problem
#8 buxvan
buxvan
  • 146 posts
Posted 09 February 2009 - 10:27 PM
there is no rubber diaphragm in there somewhere like a stromberg carb, or what can wear out & cause the problem, my starter motor is getting annoyed as i'm using it loads lately !
#9 crizd
crizd
  • 187 posts
Posted 10 February 2009 - 07:21 PM
#10 Darkscamp
Darkscamp
    Drives the 'Thing'
  • 1,475 posts
  • Local Club: Lone Ranger
Posted 10 February 2009 - 07:25 PM
same problem here, only get about 100 miles before it needs topping up again, even changed the carb for a reconditioned one and that does the same. i have a few mates that have the same problem as well, its confused the lot of us as other people we know very rarely top theres up.
#11 icklemini
icklemini
  • 2,982 posts
Posted 10 February 2009 - 09:09 PM
tried *not* removing the piston to top up?
you using engine oil?
#12 Darkscamp
Darkscamp
    Drives the 'Thing'
  • 1,475 posts
Posted 10 February 2009 - 09:16 PM
i used to use engine oil in the old carb, but then i changed to atf(automatic transmission fluid) as recomended by a experienced mini specialist when it went in for some engine work, and thats all i've ran the new carb on but still it disappears.
