Hif Carb Oil Problem
Posted 08 February 2009 - 09:36 PM
i top up the dashpot & within 2 days it has emptied.
where is the oil going & is this why the car stalls when i dip the clutch when slowing down?
thanks in advance
Posted 08 February 2009 - 10:09 PM
Posted 08 February 2009 - 10:53 PM
Posted 08 February 2009 - 10:57 PM
owner then thinks "oo wheres that oil gone" - fills it up to the brim.. spends 5 minutes trying to push the piston back in...
then repeat the next time its checked...
Posted 08 February 2009 - 11:12 PM
Posted 09 February 2009 - 04:56 PM
Posted 09 February 2009 - 05:19 PM
Posted 09 February 2009 - 10:27 PM
Posted 10 February 2009 - 07:21 PM
Posted 10 February 2009 - 07:25 PM
Posted 10 February 2009 - 09:09 PM
you using engine oil?
Posted 10 February 2009 - 09:16 PM
tried *not* removing the piston to top up?
i used to use engine oil in the old carb, but then i changed to atf(automatic transmission fluid) as recomended by a experienced mini specialist when it went in for some engine work, and thats all i've ran the new carb on but still it disappears.
