Run Out Of Room For My Filter!
19 replies to this topic
#16 Macming
Macming
  • 81 posts
  • Local Club: Miniclan
Posted 10 February 2009 - 05:24 PM
I took my manifold to my local friendly machine shop and they faced both flanges down to 8mm thick . I've got a total face to face size of 62mm, they also machined the insulation block down to 8mm thick, ( remember you've got to modify the studs on the carb side, they will now be to long and will foul on the carb body) Another dodge is an adjustable engine steady, with a bit of fiddling and watching the strain and angles you put on the exhaust this will give you a little bit more clearance from the bulkhead.
Mine has been on for over ten years now with no trouble or damage
#17 Asphalt
Asphalt
  • 2,173 posts
Posted 10 February 2009 - 05:30 PM
- Different manifold
- thinner spacer (no spacer means the throttle cam to catch on the manifold)
- different angle (machined manifold flange on head w/ accordingly mirrored/machined faces for manifold nuts),
might work with a Maniflow LCB for injection engines (is a little lower, hence more space for a lower manifold) and cut/bend heatshield
Hmm - looks like there's no 'easy' solution... :shifty:
For the angled inlet maybe ask here:
http://www.innocenti-mini-bits.de
#18 paulrockliffe
paulrockliffe
  • 1,763 posts
Posted 10 February 2009 - 05:58 PM
Hmm - looks like there's no 'easy' solution... :-
I think I can just about get the filter on actually now I've trial fitted it. It's going to be very tight, but I can nibble the edge of the scuttle panel a tiny bit if necessary, think it'll just about pop on and then maybe it'll come off again if required....... maybe! I have five cones, so if need be I can cut them off to remove.
If it turns out I can't get the end of the filter on, I'll sand a spare spacer down and hope for the best!
Right, need some gaskets and maybe a little fuel pipe and a throttle cable, so I might pop down to Moss in the morning.........
#19 Kerrin
Kerrin
  • 1,056 posts
  • Local Club: Manx Mini Register
Posted 10 February 2009 - 08:14 PM
Have a look at the howley/torquemaster type inlets, the carb sits lower than the MG metro it might give you a bit more bonnet clearance.
Also what about a trumpet and filter sock.
#20 mini_kel
mini_kel
  • 2,851 posts
  • Local Club: EMC/No pub mini club
Posted 10 February 2009 - 08:44 PM
I may have one of the torquemaster inlets laying around i`ll check it for size against MG type for you
