hey
recently my head gasket went and i am in the process of fixing that.
My head has been skimmed.
I looked at the block face today and it is covered in rusty deposits etc and grime.
how do i clean this etc??
thanks
Engine Block Cleaning
ianpettifer
, Feb 10 2009 01:01 PM
6 replies to this topic
Posted 10 February 2009 - 01:01 PM
Posted 10 February 2009 - 01:10 PM
Help needed asap
Posted 10 February 2009 - 04:09 PM
get a paint scraper the type with a stanley blade in and go over the block with that, be carefull not to dig into the block with the blade, that will get most off.
or just use a stanley blade, with some tape over the blunt end, it still hard on the fingers though.
Edited by rozzer1275, 10 February 2009 - 04:10 PM.
Posted 10 February 2009 - 04:24 PM
you could use a degreaser to clean up the block a little, then use a wire brush to remove the flaking rust
Posted 10 February 2009 - 04:50 PM
Gunk is pretty good stuff to use as well!
Posted 10 February 2009 - 05:01 PM
Some 1200 grade sand paper lightly over it normally does the finer bits of gunk and grime stuck to it.
If doing this, Put some rags down the bores so any swarf doesnt drop into the cylinders/pistons/piston rings.
Jordie
Jordie
Posted 10 February 2009 - 05:16 PM
Thanks everyone i have a clean block now
