Pin In Gearbox Linkage
8 replies to this topic
#1 RONNIE
RONNIE
  • 88 posts
  • Local Club: N/A
Posted 10 February 2009 - 08:28 PM
hi guys,
any tips or advice on what is the easiest way to get the pin out of the gearbox lingage??
cheers
#2 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 10 February 2009 - 08:29 PM
With a proper roll pin punch.
#3 Brigbeale
Brigbeale
  • 287 posts
  • Local Club: Bournemouth Mini Club
Posted 10 February 2009 - 08:33 PM
A samll drift/roll pin punch the same diameter as the pin.
Don't try a nail - they are too soft and usually get stuck (I tried this once out of desperation when someone 'borrowed' my drift and failed to return it as they 'lost' it :-
Mini Spares Gear Selector Roll Pin Punch Tool. Item no - Tool 17. £2.50 ex vat. £2.88 inc vat.
Edited by Brigbeale, 10 February 2009 - 08:39 PM.
#4 BishopMaverick
BishopMaverick
  • 163 posts
Posted 10 February 2009 - 08:44 PM
Was going to remove mine tommorrow as well... are they the same as parrell pin punches or not (sorry if this is stupid question don't want to damage my tools or the pins)
Cheers,
Bishop M.
#5 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 10 February 2009 - 08:49 PM
A parallel pin punch will be flat ended, a roll pin punch has a stepped nose that locates inside the pin and stops the punch jumping around as you strike it. Both will work but the roll pin punch will be easier. Whatever you use make sure it is flat where it drives the pin, if you use a tapered or sharp ended drift or punch it will spread the roll pin as you hit it and only cause the pin to hold on tighter.
#6 Brigbeale
Brigbeale
  • 287 posts
Posted 10 February 2009 - 08:50 PM
Cheers,
Bishop M.
I've not used one, but I think that the proper pin punch had a smaller nib which fits in the hole of the roll pin to locate it and the shoulder of the punch is what pushes the pin through.
#7 BishopMaverick
BishopMaverick
  • 163 posts
Posted 10 February 2009 - 08:53 PM
Thanks Guys!!!! :-
#8 Pauly
Pauly
  • 4,213 posts
Posted 10 February 2009 - 08:54 PM
Put it in reverse aswell, makes it easier.
Paul.
#9 BishopMaverick
BishopMaverick
  • 163 posts
Posted 10 February 2009 - 09:05 PM
Paul.
Thanks :- ... I have now put that in my mini Bodge repair book I have stated compiling for myself.
Bishop M.
