Moving Pedal's
3 replies to this topic
#1 Flukey
Flukey
  • 67 posts
Posted 10 February 2009 - 10:08 PM
Hey guys just a quick question. Is it possible to move or bend the accelerator, brake and clutch pedals so they are further appart? or even bend them? it would be nice to have them a tad further appart :-
cheers
Luke
#2 mike.
mike.
  • 6,176 posts
Posted 10 February 2009 - 10:13 PM
You won't be able to bend them - Infact its probably a pretty bad idea to.
You'd have to modify them so the clutch sat close to the exhaust tunnel - Which its pretty close to anyway, also the throttle is already pretty close to the bulkhead.
So really it'd take alot of work for not much gain since you'd have to remove the pedal box to grind/reweld the pedals...
#3 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 10 February 2009 - 11:04 PM
You can fit a LHD clutch pedal, this will move the pedal pad about 1.5" further away from the brake but it does put it a bit too far under the heater really. As for the throttle, there are many throttle pedal extensions available from Mini specialists.
#4 998dave
998dave
    998cc's Of Dave Goodness
  • 4,566 posts
  • Name: Dave
Posted 11 February 2009 - 12:24 PM
You can, my Hornet has a very jammed clutch master cylinder, so I pushed on the pedal and bent the clutch pedal arm sideways.
New clutch pedal now required - which is a little annoying.
Dave
