Hello,
I have been fitting a pair of new KAD 4-pots this evening. When I ordered them I specced the type needed for a solid disc.
Now they are on the car, the disc does not sit in the centre of the caliper - the outside pistons are much closer to the disc surface than the inside pistons. Does anyone know if this is normal? Maybe I have been sent the vented type instead?
I'll try and get some pics tomorrow when its light...
Thanks, Kieran
Kad 4-pots
lotusk
, Feb 10 2009 10:17 PM
3 replies to this topic
Posted 10 February 2009 - 10:17 PM
Posted 10 February 2009 - 10:55 PM
Have you fitted the pads as if they are wrong then you will have a massive gap where the rest of the disc should be!
Posted 10 February 2009 - 10:57 PM
Are you using 8.4" or 7.5" discs?
Posted 10 February 2009 - 11:16 PM
I am using 8.4" solid discs and yes, there is a large gap from the pad to the inside of the disc.
I didn't have time to bleed them but I presumed the pistons would just extend more on the inside until the pads make contact with the discs... I guess it sounds like I have the vented calipers?
