Setting Off
6 replies to this topic
#1 spennyy2k
spennyy2k
  • 111 posts
  • Local Club: south lancs mini owners club
Posted 14 February 2009 - 05:00 PM
Model:austin mini 1000
Year:1982
Description of problem (please be as in depth as possible):drove the car for about 5 minutes to my sons school, was sat outside for around 15 mins ticking over but with the heater on since then once the engine is warm as soon as you touch the accelerator the engine goes like it is choking itself and trying to stall, put your foot down a bit more you can push thru this and will run fine, moving at speed it is fine just the initial set off. I have checked a few things oil,water dashpot all seem ok, coil is only a few months old timing clamp on the dizzy is tight so that hasnt moved. am going to have another poke around tomorrow if i get a chance , anyone have any ideas where i should be looking
Any non-standard parts that might be involved with the problem?only non standard part is the electronic ignition from http://www.britishmi...p?topic=20180.0
#2 mister bridger
mister bridger
  • 912 posts
Posted 14 February 2009 - 05:21 PM
Might be worth cleaning/replacing plugs. Not usually a prob on my mini but my other car does tend to foul the plugs if idling for a long time
#3 spennyy2k
spennyy2k
  • 111 posts
Posted 14 February 2009 - 06:19 PM
ok ill try that, plugs are fairly new also
#4 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 14 February 2009 - 07:13 PM
HT Leads, Dizzy Cap, Rotor Arm, Contact Breaker Points and Condenser are probably worth checking too?
#5 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 14 February 2009 - 07:31 PM
Could be running rich too. Is the choke returning properly?
#6 spennyy2k
spennyy2k
  • 111 posts
Posted 14 February 2009 - 07:42 PM
that is the only other thing i can think of, wont be the condeser/points as its on electronic
#7 Pauly
Pauly
  • 4,213 posts
Posted 14 February 2009 - 08:45 PM
Bogging down, sounds like a rich mixture.
Paul.
