I have been asked by a friend to see if anyone would be interested in a swiftune full race engine that he has.
The engine was built by swiftune about 8 years ago at a cost of between 7-8 thousand pounds and was the absolute full race engine used in Brisca Mini Stox.
The engine has been standing for a few years but turns over easliy by hand and has not seized.
Ideally it would need a basic rebuild as it hasnt been started for a few years, just a simble big end and rings change woul be fine.
The spec of the engine is something like this:
850 block bored +40 to 997(I think)
12g295 full race head (big ports and valves)
Fully worked lightened, balanced, wedged, bladed x drilled and hardened crank (over £1k to do)
Lightened and balanced conrods
Uprated pistons (omegas I think)
Points distributer with custom advance to suit engine
Lightened distributer drive
Full conversion to cam belt with vernier pulleys
Modified timing covers to allow adjustment of timing without stripping anything to change for different tracks.
1.5 full roller rockers
286 cam
Race restrictions at the time limited all engines to standard 1"1/4 carb and standard manifolds, but if a bigger carb, inlet manifold and LCB were used then some descent power figures would be acheived.
The quality of the build is that good that the engine used to be raced every weekend (with regular oil changes) and used to be at the end of the straight happily at near 8,000rpm !!!
I havent posted this in the for sale section as he doesnt know a price and would like to see how much interest he has.
Thanks.
Edited by 1275 SPRITE, 17 February 2009 - 08:57 PM.
