Driveshaft Query
6 replies to this topic
#1 cerbera
cerbera
  • 36 posts
Posted 15 February 2009 - 07:07 PM
Currently in the process of converting a 69 Mini, to a MPI. My Mini is using discs under 10" wheels, and I want to keep it on 10's. The old driveshafts were the hardy spicer type, however I intend to use the new driveshafts from a 98 Cooper. Will the driveshafts from the 98 Cooper, fit into the hub's of the 69 car?
#2 Nightrain
Nightrain
  • 976 posts
Posted 15 February 2009 - 07:41 PM
Yes there the same as long as there 'S' disc's and not the smaller 7" 998 cooper type.
#3 blacktulip
blacktulip
  • 6,231 posts
Posted 15 February 2009 - 07:46 PM
im doing the exact same thing this week.
#4 cerbera
cerbera
  • 36 posts
Posted 15 February 2009 - 07:49 PM
What size are the 'S' discs and I'll go and measure them now. Knowing my luck they are going to be the smaller ones. Fingers crossed.
#5 Nightrain
Nightrain
  • 976 posts
Posted 15 February 2009 - 08:06 PM
Measure the outside diameter of the disc, S disc's are 7.5" and copper disc's 7". Another quick way to tell would be what size nut is the hub nut ? Same size as the mpi and there S disc's (1-5/16") Smaller and there cooper disc's.
#6 cerbera
cerbera
  • 36 posts
Posted 15 February 2009 - 08:15 PM
Thanks for your help, couldn't measure them properly as my Locking wheel nut key is in another garage! but measured from the rear and unfortunately I think they are going to be 7" - Couldnt measure the exact diameter, as the hub/driveshafts are in the way.
And I suppose Cooper S discs/hubs are a bit like Hens teeth ?
#7 Nightrain
Nightrain
  • 976 posts
Posted 15 February 2009 - 08:30 PM
Easiest hubs to find, fitted to just about every mini since they went to 12" wheels, although not strictly S hubs. They are the same, some will need cleaning up a bit, to fit inside the S disc.
