Rings and Shells,
Posted 18 August 2005 - 12:00 AM
Anyways, The Pistons I have are 20831a but I can't find any rings for them and also the main shells are they uprated or can standard 1275 shells be used?
Sorry for all the Questions
Posted 18 August 2005 - 07:44 AM
The shells you requre will depend on the condition of you mains and big ends on the crank... check them or get them checked with a micrometer, for both size and ovaling.... anymore than a couple of thou off and you'll need a regrind...
the std 1275 shells should be ok
*edit* read again...
Turbo Pistons.... and therefore Turbo shells required, I think the lower shell has the tab in a different place, look at you main cap and that'll make it obvious.
Edited by GuessWorks, 18 August 2005 - 07:48 AM.
Posted 18 August 2005 - 08:25 AM
according to their lists the piston rings for a std metro turbo are as follows...
1st: 1.50 mm
2nd: 1.50 mm
3rd: 3.00 mm
Bore DIA : 70.61 mm
Hepolite Ref: R41570
Ultraparts Ref: RS302
Posted 18 August 2005 - 05:03 PM
As for the rings minispares list them but don't know how the cost compares with anywhere else http://www.minispare....aspx?pid=34929
Posted 19 August 2005 - 09:47 AM
I rung up mini spares and as a word of warning to anyone else that has turbo pistons and wants rings, these are only suitable for a certain piston type. When I asked them about my piston type they said that they have a backlog of orders and that I would be waiting 6-8 weeks and even then they couldn't promise me that it wouldn't be longer.As for the rings minispares list them but don't know how the cost compares with anywhere else http://www.minispare....aspx?pid=34929
I spoke to Ian at Avonbar yesterday and he said that the piston rings for these pistsons were dis-continued over 2 years ago!
I do however have a set coming today courtesy of an engine recondintioner who is gonna make up a custom set for them.
So all is not lost yet.
Thank you for the Help though Guys much appreciated.
Posted 20 August 2005 - 12:15 AM
Have you noticed though that the link that GuessWorks posted shows the turbo rings to be exactly the same part as the standard rings. This cannot be right can it
Posted 20 August 2005 - 07:16 AM
I bought mine from this place, They were superb, took the piston kept it overnight and next day the rings were here.Oh ekers I'll be after a set of these in the next couple of months.
Smiths Engine Service
Burnt Mills Industrial Estate
Basildon
Essex
SS13 1EG
Tel: 01268 726826
in total they come out at 71.85 which is slightly above what normal rings are, but in this case the extra was worth it after spending 2 days ringing round to be told there no longer made or there is a 2 month waiting list.
When it comes round to you needing them, give me a shout and I can go down there and collect them and send them onto you if you like.
Posted 20 August 2005 - 05:09 PM
Cheers bud :cheese:
