How Do You Test For A Short In A Circuit
33 replies to this topic
#1 Allybally
Allybally
  • 58 posts
Posted 27 February 2009 - 05:00 PM
i have bought a electric multimeter, a Sealey one, (see picture) im just wondering what settings i need it on to be able to tell if a wire has a short, and which hole do i stick the red probe into, and how this is achieved, please help
Allybally
cooper 1.3i
1993
#2 il-barba
il-barba
  • 839 posts
  • Local Club: malta mini
Posted 27 February 2009 - 05:41 PM
if my memory serves me right,
you stick the red probe in the middle hole, the black in the bottom hole. then i think you need to set it on resistance so that if you have zero resistance it will be a short circuit
#3 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 27 February 2009 - 06:12 PM
ohms scale and a low reading for a short circuit and a high reading if everything is ok
#4 Allybally
Allybally
  • 58 posts
Posted 27 February 2009 - 07:49 PM
Q1 Great thanks guys, ive put my dial on 200 Ohms, and the 2 probes into where there supposed to be, the screen is reading 1, is this right?
Q2 theres a couple of other things, it has been mentioned that it gives a low reading if there is a short (is this lower than 1 or just a tiny bit higher than 1?)
Q3 and if the circuit is fine it reads higher than 1 or loads higher than 1?
it would be good if someone could help me out with that part,
Q4 and also when i find what wire i want to test for a short, what do i do, am i right in thinking i put the red probe into the suspected shorted wire, but where do i put the black probe, do i put it onto any eart, or on the other end of the suspected wire,
Q5 and do i have the ignition on or off
any help would be most appreciated
many thanks for your help and patience
Allybally
#5 Jupitus
Jupitus
  • 1,479 posts
  • Local Club: Breathemini
Posted 27 February 2009 - 07:51 PM
If you set it to the one at the bottom right with the triangle with a line through and cross line (it's actually the symbol for a diode) I would expect the tester to make a beep if you touch the probes together... if this is the case then you have an audible connectivity sensor, ie something that says 'these 2 points are connected through conductive material'.... at least my tester does that on the diode setting :cry:
#6 Jupitus
Jupitus
  • 1,479 posts
Posted 27 February 2009 - 07:54 PM
Allybally
Try what I just posted to see if you have a continuity test feature. If so then touch one probe on suspect wire and other on what you think it is shorting to, ie nearby bodywork or another wire etc - if it beeps they are connected.
I would test with ignition on.
#7 Allybally
Allybally
  • 58 posts
Posted 27 February 2009 - 07:55 PM
is that symbol the continuity tester or is that something different, and when its on that if i touch the 2 together it doesnt beep, it shoots up then settles to read 1, is this correct, does it still do the same thing
#8 Jupitus
Jupitus
  • 1,479 posts
Posted 27 February 2009 - 08:02 PM
It's only useful if it's audible - my tester is a different one, sorry... I just pulled up the manual for your tester and you were on the right lines before. Put is back to the 200 ohm setting (should be one click clockwise) and carry on, but you'll need to be able to see the readings... if the figure is '1' it is probably showing that to indicate an out of range error, ie the resistance is way over 200 ohms, ie no conductivity or no short.... look for it to drop to zero or a number other than 1.
#9 Allybally
Allybally
  • 58 posts
Posted 27 February 2009 - 08:05 PM
right ive just been trying it with a few scraps of wire, when its on the (arrow triangle) symbol, if the wires are connected, the red probe sends a current through the wire which is picked up by the black probe which joins the circuit and reads as a positive current on my screen
is this right
thanks
#10 Allybally
Allybally
  • 58 posts
Posted 27 February 2009 - 08:07 PM
so if there is a short it will read lower than 1, and if its fine it will read higher than 1
#11 Jupitus
Jupitus
  • 1,479 posts
Posted 27 February 2009 - 08:08 PM
Sorry Allybally - that was me mmisleading you - I have checked the user manual and you tester doesn't have the feature I was describing :cry:
#12 Allybally
Allybally
  • 58 posts
Posted 27 February 2009 - 08:10 PM
bolloxs, i knew i shouldnt i bought the cheap 1, what do i need to look for on the box before i buy it
#13 Jupitus
Jupitus
  • 1,479 posts
Pretty much, although there could still be some resistance giving a reading over 1 ohm (unlikely though)... the device will display exactly 1 to indicate an out of range error though.
NOTE: WHEN THE FIGURE ‘1’ IS DISPLAYED, IT INDICATES AN OVER-RANGE SITUATION AND A HIGHER RANGE NEEDS TO BE SELECTED.
#14 Jupitus
Jupitus
  • 1,479 posts
Posted 27 February 2009 - 08:11 PM
No no no - that's fine!!! It will work!!! :cry:
#15 Jupitus
Jupitus
  • 1,479 posts
... and if it doesn't you are only in Lip hook - pop up to Sandhurst tomorrow and borrow mine!
Edited by Jupitus, 27 February 2009 - 08:12 PM.
