Would A Short In The Circuit Cause This (see Picture)
Posted 28 February 2009 - 11:10 AM
cooper 1.3i
1993
this is the 2nd time its happened with 2 different modules
Allybally
Posted 28 February 2009 - 11:42 AM
Posted 28 February 2009 - 12:35 PM
Yes it could. Moved to the injection section where someone will know what part of the system is related to the burned track.
Thanks Mate
Posted 28 February 2009 - 02:42 PM
Posted 28 February 2009 - 04:00 PM
Posted 28 February 2009 - 04:04 PM
does anyone know where the main relay is?
and what is a Fusable Link, and where are they?
Posted 28 February 2009 - 06:55 PM
Check the terminals in the connector plug. Remove the white ant back out cover by prising it up and away from the connector. The terminals look much like normal spade terminals.
The fuse links are under the sleaving down by the starter motor. The brown/ pink suplies the ECU, Injector, Coil, Stepper Motor, and purge valve. The burning of tracks for the Main relay switched supply and the starter motor switched supply, because they are two independant circuits, I would suspect that it is the connector that is the problem rather than anything else. The one that normaly burns is the manifold heater which looks ok there.
Posted 28 February 2009 - 08:32 PM
Burning like that normaly only happens there because of a bad connection.
Great thanks, its getting me there, and your saying that the problem is the actual connectors, not the relay module, so i take the cover off the connector and clean it up, should i use wet and dry or just a rag, or do i need to buy a new connector,
thank you so much
Allybally
Posted 28 February 2009 - 09:13 PM
Posted 01 March 2009 - 11:15 AM
You may find that the terminals have opened up a little, if they are not damaged you can close them up a little with a pair of pliers. If they themselves are burnt you will have to replace the terminals, which are available from Polevolt
Thanks Mate im going to look now
Allybally
Posted 01 March 2009 - 05:09 PM
Allybally
