Brake Light Switch Needs Adjusting...?
27 replies to this topic
#16 yorkshirechris
yorkshirechris
    11.11.11
  • 3,873 posts
  • Local Club: www.lcmoc.com
Posted 01 March 2009 - 05:05 PM
Cheers for the info :shifty: the Minispares website shows two different switches, there's one which is pre-'76, and another which says it is for '76-on, and it floor mounted? ;D I guess I will just have to have a look at mine and see what type it is. Those diagrams will come in handy.
#17 Wakey-Dan
Wakey-Dan
  • 256 posts
Posted 01 June 2013 - 09:31 AM
Holy thread revival batman. Im replacing my brake switch as the connectors have come loose on mine. How do i take the old one off? Do i have to undo the nut beind first or can i just screw/turn the switch off?
#18 Wakey-Dan
Wakey-Dan
  • 256 posts
Posted 01 June 2013 - 09:32 AM
Its the later type switch
#19 tiger99
tiger99
  • 8,584 posts
Posted 01 June 2013 - 12:29 PM
You should unscrew the nut, and remove the switch, with its adjusting bracket, complete, so you can easily remove it from the bracket. Otherwise the nut that fixes the switch itself is well-nigh impossible to reach.
The first link shows the switch bracket, item 22:
http://www.somerford...page=page&id=58
The second link shows the switch, item 83, and the nut holding it to the bracket, item 84.
http://www.somerford...page=page&id=87
#20 carmo
carmo
    Just On Tickover
  • 8 posts
Posted 10 September 2016 - 02:25 PM
Glad I came across this post from DK Lawson as I have the hydraulically actuated switch that has failed and I didn't know where to look for it  until now. By the way can the hydraulic switch be repaired, other wise I will have to wait until Monday to get one.
#21 Spider
  • 15,222 posts
Posted 10 September 2016 - 07:40 PM
Fit a Hella Brand one, the others that seem to be available these days don't last too well.
Hella P/N 4565.
#22 tiger99
tiger99
  • 8,584 posts
Posted 11 September 2016 - 10:09 PM
No, the hydraulic switch can not be repaired, and bodging it would be extremely dangerous.
#23 carmo
carmo
    Just On Tickover
  • 8 posts
Posted 13 September 2016 - 01:13 PM
Thanks Moke Spider & tiger99..new switch on its way.
Help if you can, the moke  indicator control arm bulb (new) is not working but the indicators front and back are working fine. I can only find two fuses and both ok, meter tested.
Thanks again.
Sean
#24 AeroNotix
AeroNotix
  • 267 posts
Posted 13 September 2016 - 02:06 PM
Having replaced mine today I would recommend loosening 20/21 so 19 can come free making it much easier to tighten up the nut on the back of 19 where the new switch attaches: https://www.minispor...s-and-cylinders
Edited by AeroNotix, 13 September 2016 - 02:07 PM.
#25 Spider
  • 15,222 posts
Posted 13 September 2016 - 08:29 PM
Thanks again.
Sean
The Repeater  Lamp on the end of the Switch doesn't work?
It's been a long while since I played around with one of these, but first place I'd be inclined to look is the Flasher Can. It needs to be a 3 Pin type and check the labelling of the Pins, they should be X (or B), P and L. If they are numbered, I'd be suspect that it's the wrong can.
With the Indicators on (either side), check you are getting 12V (puling in time with the Indicators) on Terminal P, that's the one that powers the Repeater Lamp. If that doesn't work, it's the Can, if it does, then it's in the wiring somewhere, but I'd probably then check there's an Earth to the Repeater.
#26 Podman
Podman
  • 215 posts
  • Local Club: Snowdon Minis
Posted 11 February 2025 - 04:58 PM
Can I revive a revived thread? I take it the earlier pedalbox did t have the slots, hence the hydraulic switch? ☹️
#27 Spider
  • 15,222 posts
Posted 11 February 2025 - 06:25 PM
The cars built with Single Circuit Brakes had a Hydraulic Switch. When they went to Tandem Circuit, they went to a Pedal mounted Switch.
#28 Podman
Podman
  • 215 posts
Posted 11 February 2025 - 08:42 PM
