Smoother Ride On My Mini
18 replies to this topic
#16 mk1leg
mk1leg
  • 9,343 posts
Posted 05 March 2009 - 06:00 PM
Stick to Minisports ajuster rides as HI-los will need a hole drilled in rear valance to ajust them where ajuster rides just use a large spanner and if and when you come to fit them(ajuster rides) do both nuts up and then using a center punch, punch outter nut on a flat, and punch opp on ally cone then this makes it eaiser to count when you ajust the hight 3 full turns equals std ride hight............. :D
Edited by mk1leg, 05 March 2009 - 06:02 PM.
#17 Jammy
Jammy
  • 25,397 posts
Posted 05 March 2009 - 06:19 PM
The Hilos use a large spanner too. At least the last two sets I bought did.
#18 twiglett
twiglett
  • 211 posts
Posted 05 March 2009 - 07:28 PM
or alternatavely(sp) you could fit coil springs instead of doughnuts, new decent shock absorbers and hi-lo`s
i havent tested mine yet but im sure they will be oh so much smoother than the old stuff
my set up is;
huddersfeild spares red coilsprings all round,
cheap hi-lo`s all round + new knuckle joints,
gaz lowered height adjustable shocks
tons of grease over every moving part and although they probably wont make adifference to ride comfort
full adjustable geometry kit with poly bushes.
Edited by twiglett, 05 March 2009 - 07:30 PM.
#19 redhotmini
redhotmini
  • 1,607 posts
Posted 05 March 2009 - 08:01 PM
trust me you'll need loads of grease to make those springs run silent - the bang about if its not setup right.
