Gaz Shocks
22 replies to this topic
#1 watto1minis
watto1minis
  • 77 posts
Posted 09 March 2009 - 09:59 AM
Hi Guys,
just bought some GAZ shocks and just wondered what settings you had yours at.
Front??
Rear ??
thank you
#2 watto1minis
watto1minis
  • 77 posts
Posted 09 March 2009 - 04:12 PM
anyone??
#3 Darkscamp
Darkscamp
    Drives the 'Thing'
  • 1,475 posts
  • Local Club: Lone Ranger
Posted 09 March 2009 - 04:14 PM
i always set mine at 3/4 front, 1/2 rear. run it for a week or so then adjust accordingly for balance and ride comfort
#4 watto1minis
watto1minis
  • 77 posts
Posted 09 March 2009 - 04:18 PM
thanks for the reply.
has anyone else got any others setups differently to above?
#5 Prawn
Prawn
  • 938 posts
Posted 09 March 2009 - 04:28 PM
it really depends on the weight of your car and what your main use is really mate....
When I used mine dailly I used to run about 20 clicks front and 16 rear, which on a 36 point setup is roughly the same as Darkscamp said :thumbsup:
#6 Mini_Magic
Mini_Magic
  • 5,747 posts
Posted 09 March 2009 - 07:16 PM
I had mine on the softest setting, for comfort as it was a daily driver.
#7 zap
zap
  • 333 posts
Posted 09 March 2009 - 07:55 PM
Hi Guys,
Front??
Rear ??
thank you
hey thanks for asking the question i tried in suspension bit but no reply's.
Just order mine as well, and a mini spares rac hi lows for the back. :thumbsup:
Cant wait to fit them, fed up with being bounced up and down all the time
Edited by zap, 09 March 2009 - 07:55 PM.
#8 zap
zap
  • 333 posts
Posted 13 March 2009 - 07:47 PM
Well fitted one side of the rear shocks, and hi and low, all is good apart from when i home, it was set to 16 clicks, because everyone says this is good setting.
but i found this way to hard bounce all over the place, so set it to fully soft and it is much better, do i leave them at fully soft, or do i have to wait a week and run them at 16.
What do gaz shocks adjust to 36 point 28 point ?? I did one shock and i counted 40 clicks then on another 36
Doing the other side tomorrow. dreaded fuel tank lol.
#9 zap
zap
  • 333 posts
Posted 14 March 2009 - 11:22 PM
Well today fitted the other side, and front dampers as well, and omg the handling is so much better, lowered the rear as well :D
#10 Darkscamp
Darkscamp
    Drives the 'Thing'
  • 1,475 posts
Posted 14 March 2009 - 11:36 PM
have you decided what settings your going for?
on a personal note i would always go a little stiffer on the front than the rear.
#11 reffle
reffle
  • 80 posts
Posted 15 March 2009 - 11:16 AM
I'm getting these next week as my current shocks seem to have given up (not that they did much in the first place :D ) Think I'll try the softest for daily driving. I understand that I'll need to drain the fuel tank though!
#12 robtheplod
robtheplod
  • 960 posts
Posted 15 March 2009 - 11:22 AM
I've got GAZ adjustables on both front and rear and have all on as soft as they will go. We did try other settings, but got trapped in a kangaroo trip up one road that had regular marks on the road!! (great fun but felt sick after a few minutes).
#13 T.Harper
T.Harper
  • 714 posts
Posted 15 March 2009 - 12:27 PM
I literally messed around with them for a week then put them on softest because it's my daily drive.
#14 zap
zap
  • 333 posts
Posted 15 March 2009 - 06:15 PM
Well i think they are way to stiff at the moment, so i think i will put them at there softest setting, because it is my daily drive, but not sure i should yet, maybe give it a week, to see if things improve.
Yes i will put the front shocks sightly stiffer at the front
#15 zap
zap
  • 333 posts
Posted 15 March 2009 - 06:17 PM
I'm getting these next week as my current shocks seem to have given up (not that they did much in the first place ;) ) Think I'll try the softest for daily driving. I understand that I'll need to drain the fuel tank though!
They are so much better mate, well worth the moeny, only fitted them yesterday,
i did not drain my tank, because it was below half fall, i was amazed how flexible the fuel pipes were. I just moved it into the middle of my boot. :D
