Excessive Play In A Lower Suspension Ball Joint
18 replies to this topic
#16 mad4mins
mad4mins
  • 1,396 posts
  • Local Club: WAMO!
Posted 11 March 2009 - 10:33 AM
the kits is not that expensive and worth doing!
#17 daemonchild
daemonchild
  • 2,341 posts
  • Local Club: Unknown
Posted 06 October 2009 - 03:09 PM
I was just looking through my old threads for something.
Wow: how far I have come!! This used to be hard stuff to me. Now I'm not stressed about it at all. :P :P
:thumbsup:
#18 Frog
Frog
  • 492 posts
  • Local Club: Blakehill Mini's
Posted 06 October 2009 - 08:14 PM
:thumbsup:
You could buy a kit just to be on the safe side but then again you could get away with just removing some shims to take the play out as very often this is all that is needed, when was the last time it was greased, if used regularly then it should be greased every 3 months, this stops premature wear.
#19 icklemini
icklemini
  • 2,982 posts
Posted 08 October 2009 - 09:47 PM
Note that the lower ball joints have a spring in them... this spring pushes the pin against the cup.
as the ball joint wears away, the spring pressure takes up the slop... as it wears some more.. the spring takes up the slop...
If the bottom ball joint has gone far enough to fail the MOT, its because it is well worn out... reshimming the bottom balljoint is certainly not recommended in this circumstance.
The top ball joint has no spring, and whipping a shim out can take out some slop..
