No Bypass & No Holes In The Thermostat
18 replies to this topic
#16 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 12 March 2009 - 06:27 AM
really depends how many holes you have drilled... I usually recon on 3 done by a panel hole punch, then again I don't run a thermostat, so my temp gauge rarely moves at all...
Why aren't you running a thermostat john?
My engine seems to run better cold... well technically it's not cold, probably running about 60 degrees rather than 80.
#17 adcyork
adcyork
  • 490 posts
Posted 12 March 2009 - 11:13 AM
What spec is it if you don't mind me asking?
#18 minimadjonesy
minimadjonesy
  • 6,417 posts
  • Local Club: SMAC
Posted 12 March 2009 - 11:24 AM
i don't run a thermostat either and mine gets up to temp ok! I have a blanking slieve in place of the thermostat though!
#19 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 12 March 2009 - 05:33 PM
I run a sleeve too.... while I'm stationary the temp will come up, but when on a run it'll go all the way down...
