Heel and toe...
Posted 23 August 2005 - 10:15 PM
Posted 23 August 2005 - 10:16 PM
ask teapot he will remember :smartass:
Posted 23 August 2005 - 10:20 PM
My bro managed to heel-toe to pull away on hills when the handbrake broke on his midget.
Posted 23 August 2005 - 10:23 PM
Posted 23 August 2005 - 10:27 PM
Posted 23 August 2005 - 10:31 PM
Posted 23 August 2005 - 10:35 PM
Posted 23 August 2005 - 10:36 PM
Posted 23 August 2005 - 10:48 PM
Brake with right foot, keep toes on brake and slide the heel of your right foot over to the accelerator pedal and rev it to decided rpm.
The idea is to change gear while braking and release the clutch at the right rpm. It's mainly used for drifting, where you'd rev high so when you release the clutch the rear tires lose traction. Only way you can drift in a fwd car is to left foot brake and use the handbrake.
EDIT: Well I din't know it saves the gearbox, it might have a use for a mini afterall :grin:
I've always wanted to put a second clutch pedal to the right of the accelator, so while driving through built up areas you can keep your foot on the brake incase someone runs in front of you.
Posted 23 August 2005 - 10:55 PM
Posted 23 August 2005 - 11:05 PM
Posted 23 August 2005 - 11:25 PM
Posted 24 August 2005 - 12:58 AM
Is anyone a member of DriftWorks?
Thats why im getting out of the mini game, JDM Yo! ... :fear:
Posted 24 August 2005 - 07:11 AM
Never tried it, Not had the chance really in an auto. :tongue:
BUT is it the same priciple as bliping the throttle on a motorbike as you let the clutch out on the down shifts to stop the "over revving" sound whist engine brakeing.
I ride motorbikes day in day out, So I know all the bike manouvers. Just not the car ones yet.
Posted 24 August 2005 - 01:05 PM
But could you please explain what you mean by "double de clutching"? (ie, "You need to be able to double de clutch to be able to heel and toe".)
I note that I can't get my right foot to be able to brake and also make any contact with my right foot presently, so this "heel & towing" may be completely academic for me.
But what I currently do on almost every downshift coming up to a corner, is to brake to slow my speed, then take my right foot off briefly to keep the revs up while depressing the clutch and changing down, then taking my right foot back to the brake or leaving it on the accelerator, to take the corner.
So can you please let me know if I am "double clutching" or also doing a slight variation of the "heel & toe"?
