Oil Leak From Fly Housing And Slipping Clutch....
26 replies to this topic
#1 Mart8V
Mart8V
  • 505 posts
Posted 12 March 2009 - 11:11 PM
Just looking for some confirmation as I suspect that the oil seal around the crank has gone (new in build 700 miles ago!).
Drove a couple of hours on dual carriageway tonight and was getting loads of slipping after roundabouts in 3rd and 4th. Cd sized patch under that part of the engine about 2 mins after pulling up at home and it has been leaking more and more of late.
Seals were new as was clutch.
If it is that, how much would a garage charge in labour to fit the new part? I just do not have time at the moment.
Ta!
Edited by Mart8V, 12 March 2009 - 11:12 PM.
#2 Saxo-Fiesta-Mini
Saxo-Fiesta-Mini
  • 2,889 posts
  • Local Club: LCMOC
Posted 12 March 2009 - 11:19 PM
all depends on hole long it takes to remove most would say a minimum or 4 hours to do properly so could be anything from £100-300 pound dependin where ya go
#3 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 13 March 2009 - 12:03 AM
depends on yr of car but its between 3-5 hours so 150-300 plus parts
dave
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 13 March 2009 - 08:37 AM
What to change the primary seal ????
Experience Mini mechanic, with the correct tools should have it done in 2-3 hours...
Just had a look at the 'Rover' service schedule for a clutch plate and seal... and that's for a Rover Mechanic which may not be Mini savvy
#5 tomswain17
tomswain17
  • 90 posts
Posted 13 March 2009 - 09:30 AM
what engine are your running and does the clutch suit the power output of the engine? cause it could be that you just need a higher spec oil seal that is more resistant to leaking because of the higher output of engines.
#6 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 13 March 2009 - 09:45 AM
There's only one oil seal you should be using, the orange one... that black one which was used on the later Mpi's are shocking on higher performance engines.. however I'll openly admit there are different manufacturers which affects the quality of the seal... I use ANGUS GACO made seals both for gearbox and Primary seals.
Edited by GuessWorks.co.uk, 13 March 2009 - 09:46 AM.
#7 Mart8V
Mart8V
  • 505 posts
Posted 13 March 2009 - 01:42 PM
Orange seal in a 1330. Clutch is 1275 carb cooper 180mm Valeo one.
3 hrs?
#8 ben88
ben88
  • 30 posts
  • Local Club: basingstoke miniclub
Posted 13 March 2009 - 03:45 PM
damn im no mechanic..but i can do a clutch an oil seal i hour.
useless reply but i got bored of jus reading,lol >_< good luck with it tho
#9 Mart8V
Mart8V
  • 505 posts
Posted 13 March 2009 - 08:38 PM
So no one is disputing my theory that it is the primary seal?!
#10 mike.
mike.
  • 6,176 posts
Posted 13 March 2009 - 09:02 PM
I was charged £300 for parts and labour on my mini, that included a new verto clutch kit and the seal, just a shame it didn't fix the problem as the problem was high crankcase pressure (caused by worn rings), pushing oil through the seal.
It could also be that the seal was installed incorrectly, i've heard they are very sensitive and should be protected from the primary gear as its pushed into place as the surface of the seal is very weak/sensitive.
#11 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 13 March 2009 - 10:30 PM
The 3.5 to 4 for the MPi hours is more about right :(
#12 taffy1967
taffy1967
    Whovian
  • 9,896 posts
3 hrs?
More like a 190mm I believe?
#13 Sprocket
Sprocket
  • 7,266 posts
Posted 13 March 2009 - 10:31 PM
useless reply but i got bored of jus reading,lol :P good luck with it tho
Thats impressive even if I say so my self :(
#14 Sprocket
Sprocket
  • 7,266 posts
Posted 13 March 2009 - 10:33 PM
3 hrs?
Yes you would be correct, the 190mm plate is the correct one for the late 'Rover' 1275s :(
#15 Mart8V
Mart8V
  • 505 posts
Posted 14 March 2009 - 07:48 AM
Ah. I def have the 180mm one but that was from reading through various articles and a quick check with Minispares.
I already have a spare fly and new clutch plate anyway so would only be paying for the seal and labour.
