Engine Id
21 replies to this topic
#16 deluxe_68
deluxe_68
  • 39 posts
Posted 25 March 2009 - 08:01 AM
The first picture in this post shows the loom behind the dash and the immobiliser. Is this actually an INJECTION engine complete with throttle body?
http://www.theminifo...x...119711&st=0
Rob
It is definitely a SPI motor complete with throttle body and there is no immobilier.
Cheers Pete
#17 DaveRob
DaveRob
  • 703 posts
Posted 25 March 2009 - 08:47 AM
I agree with Sprocket here......... this is going to be a coded ECU..... you will need the body loom and the immob to go with the engine loom.
Rob
#18 deluxe_68
deluxe_68
  • 39 posts
Posted 25 March 2009 - 09:34 AM
Rob
I have got every piece of loom out of the hole car and there is no evidence of there ever being an immobiliser.
Cheers Pete
#19 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 25 March 2009 - 07:17 PM
The MNE101170 ECU is a coded Cooper unit and would 'originaly' have only been fitted to 95 onwards Coopers, the non Coopers still had the alarm wiring but the alarm itself was an option, where there is no alarm, there is a black box that looks almost the same as the alarm ECu, but all it really is is a junction box for the alarm and imobiliser wiring. These cars ALL have the wiring in the body loom for the alarm. Earlier Cooper models had an alarm that was again part of the body loom, but lacked the coding and it did not need to talk to the engine ECU.
Either the car this ecu came from has an alarm and imobiliser, or the ecu has been de coded and installed as a replacement and some one has cleverly removed all traces of the alarm wiring from the loom, which pretty much means the loom has to be taken appart at the seams.
By all means try the ecu, if it works, great, if it doesnt, it is because it is a coded unit and is not recieveing the digital code signal from the alarm ECU. :P
#20 deluxe_68
deluxe_68
  • 39 posts
Posted 25 March 2009 - 08:56 PM
The loom is the original one and has not been pulled apart at all, there are no signs of the alarm or immobiliser have ever been in there.
The ECU is the original one also, I have been told that the jap spec cars never got the alarm or immobiliser.
The engine and loom are from a 96 cooper and has been running already in this configuration.
Cheers Pete
#21 Sprocket
Sprocket
  • 7,266 posts
Posted 26 March 2009 - 10:25 PM
You know more than me :) which is not hard in all honesty ;)
#22 DaveRob
DaveRob
  • 703 posts
Posted 27 March 2009 - 03:50 PM
I feel............. educated ................ lol
Rob :)
