Stripped Thread In Sump Casting For Oil Drain Plug
Posted 15 March 2009 - 04:56 PM
I went to change the oil on my recently purchased 1992 Mini HL.
But the drain plug seemed to be cross threaded (?) ..... as much as I turned it, it didn't unscrew.
So I gently tapped a screwdriver between the bolt and the sump casting while un-screwing the bolt. I managed to get the sump plug out, but the thread in the sump casting had disintergrated, a whole load of little bits of what looked like soft broken casting came out with it.
There is now only a tiny amount of thread left (about 2 threads, in a quarter segment) but no-where near enough to even hold the plug in place.
What can I do???
Posted 15 March 2009 - 05:07 PM
hope this helps
Sam
Posted 15 March 2009 - 05:08 PM
Posted 15 March 2009 - 05:12 PM
A properly installed helicoil repair won't leak, thats the best way of doing it.
Posted 15 March 2009 - 05:37 PM
Its only a Tener, worth ago
Cheers Guys
Posted 15 March 2009 - 05:43 PM
i really dont want to drill it out and re-tap, for the reasons you said, (plus is £55)
But having a look at the mini spares "SUMP PLUG WITH TAPER FOR GEARBOX REPAIR"
Its only a Tener, worth ago![]()
Cheers Guys
Hmm £10 and you could crack your gearbox housing and that will cost you more than £55 to put right, go for a helicoil
Posted 15 March 2009 - 05:49 PM
[/quote]
Agreed. I bought a Minispares sump plug repair plug once. However I was a bit alarmed to read in the instructions that there was a risk of cracking the gearbox casing if you weren't careful! So I never used it in the end.
Posted 15 March 2009 - 06:00 PM
i shall have a good think about this one. maybe i should spend that £40 extra then
Posted 15 March 2009 - 06:03 PM
Posted 15 March 2009 - 07:35 PM
They did a fantastic job and they even machined a new sump plug complete with the magnet and it looks almost identical to a standard plug.
The only worry I had was when I came to do an oil change a tiny bit of metal came out stuck to the magnet. But I was reassured by many here (after I'd posted a picture of that offending item), that it was only the heli-coil tang that should have been removed on fitting, but it obviously fell into the block.
Anyway the heli-coil is far stronger than the original thread and so far touch wood, It's not leaked a drop of oil.
Posted 15 March 2009 - 09:14 PM
Posted 15 March 2009 - 09:40 PM
Posted 16 March 2009 - 02:37 PM
but they only use helicoils as repairs to damaged items so you dont have to re-tap or replace the damaged material
Sam
Posted 16 March 2009 - 02:46 PM
Edited by Dan, 16 March 2009 - 02:48 PM.
