You seem to be trying to fix something rather than identifying the cause?
Your wires are obviously getting wet/damp being at the front by the grill, you can however buy split plastic loom covers. Sort of like 'wire tidies' they will protect your wires from the elements a bit better and make everything look better too.
When I did the wiring for my spotlights and horn I got a hose pipe and sprayed the grill looking at where the water collect, drips and flows etc - I was then able to find best spot to route the wires and wrapped them as well as covered them in the plastic split loom cover. Use a few cable ties and it remains pretty water tight.
to be honest the car doesnt ever get wet anymore - and wont very often. Its just the headlights play up and it is definatly the bullets. They are quite kernackered. Cant understand why Rover persisted with them. But the hose pipe is a good idea! Just to be sure.
I also wanted to re-route the wires for a tidier bay. The wires also get in the way of the weather shield which can be a git.
I must say im surprised people would prefer a crimp over a soldered joint tho.
H
