Mini Rotisserie
30 replies to this topic
#1 projectjordan
projectjordan
  • 88 posts
  • Local Club: southwalesminis
Posted 02 April 2009 - 07:42 PM
will two of these:
and a 12 ft scaffold tube...
support a stripped out mini shell (no subframes etc...)
i'm planning on fabricating them over the next week, if they're up to the job...
cheers
#2 tommy13
tommy13
  • 878 posts
Posted 02 April 2009 - 08:01 PM
I made one similar in 3x2 timber. I would suggest extending the feet on either side to 3 feet and moving the diagonal braces at the sides upward so they join the centre pole near the scaffold clamp and outward near the end of the feet at the bottom if that makes sense. This is because you will not be able to mount through the centre of gravity of the body. It is very bottom heavy and if you clamp with the body rotated through 90 degrees the forces trying to twist the scaffold pole are very considerable wheras forces fore and aft along the length of the pole are only what you apply pushing and pulling at the body.
#3 Pedro
Pedro
    Starting My Mini Up
  • 2 posts
Posted 02 April 2009 - 08:57 PM
Just a suggestion...
When you are happy that the supports are stable, consider fitting 4 castors to each support so you can move the shell around the garage.
I sometimes take mine outside and turn it round to get the best use of my lighting.
P
#4 projectjordan
projectjordan
  • 88 posts
Posted 02 April 2009 - 09:03 PM
cheers, not sure about the castors, was thinking more like bolting it to the floor...
i prob' will move the diagonals further out/up, just an initial sketch,
again cheers
#5 tommy13
tommy13
  • 878 posts
Posted 02 April 2009 - 09:18 PM
Must agree with Pedro. Here's a pic of the one I made.
Attached File  IMG_1891.JPG   531.99K   133 downloads
#6 projectjordan
projectjordan
  • 88 posts
Posted 02 April 2009 - 09:37 PM
hmmm, not a bad idea. only a little more steel than i'm using anyway.
would i need all 4 diagonals if i built it as per my diagram?
#7 tommy13
tommy13
  • 878 posts
Posted 02 April 2009 - 09:53 PM
You see the 4 triangular pieces of ply I have used to brace between the diagonal on the end and the long stretcher at the bottom ?. A brace here of steel tube roughly where the top edge of the ply lies may be useful, although if you use steel/welded construction you may get away without them. It's the sort of thing which can be added once you get the car on if you feel it's a bit too flimsy. you can also ensure they positioned such that the car doesn't hit them when rotated.
Edited by tommy13, 02 April 2009 - 09:54 PM.
#8 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 02 April 2009 - 09:56 PM
i ended up buying one from, for what it was going to cost in steel and time i couldn't be bothered !! plus i was passing where the bloke lives so saved on delivery =]
CLICK CLICK
very good quality and when you compare the price to the mini machine one you can't go wrong
#9 projectjordan
projectjordan
  • 88 posts
Posted 02 April 2009 - 10:17 PM
that one looks really simple, compared to the one i've sketched.
if i'd have seen that before i bought the steel i'd have considered it...d'oh
cheers
#10 SolarB
SolarB
  • 1,399 posts
Posted 03 April 2009 - 11:29 AM
Castors are a good idea.
#11 tommy13
tommy13
  • 878 posts
Posted 03 April 2009 - 06:13 PM
I would just like to add I have measured my rotisserie today and it is only 4 feet between the castors at each end and has been perfectly stable, My first post suggested 6 feet wide which I now think would be totally OTT. Sorry about that Projectjordan.
#12 jayare
jayare
  • 2,093 posts
Posted 04 April 2009 - 07:19 PM
The rotisserie looks good. That's one flash hosepipe reel though!
JR
#13 projectjordan
projectjordan
  • 88 posts
Posted 04 April 2009 - 07:28 PM
no problem, i've made mine 3 foot apart after looking at the ebay one. i'll post an updated plan in a bit.
SolarB, have you put the post through the back seat panel to get it level?
cheers
Edited by projectjordan, 04 April 2009 - 07:31 PM.
#14 projectjordan
projectjordan
  • 88 posts
Posted 04 April 2009 - 09:32 PM
as promised:
#15 feybrand
feybrand
  • 1,247 posts
Posted 04 April 2009 - 09:41 PM
as promised:
i bought this of ebay
