Rear Spot Light
#16
Posted 09 April 2009 - 12:28 AM
#17
Posted 09 April 2009 - 09:38 AM
#18
Posted 09 April 2009 - 09:43 AM
#19
Posted 09 April 2009 - 10:56 AM
Similar to how you wire up front spots, but switched by the reverse circuit and tell-tale rocker switch rather then the headlamps and switch.
Dave
#20
Posted 09 April 2009 - 11:35 AM
Why not add another fog lamp rocker switch to the fog lamp switch panel to the right as you drive, use the reverse circuit to feed switching power to a relay, and feed the earth through the rocker switch, then take seperate 12v power from the fusebox, through an inline fuse and to the light.
Dave
you have a point, but i was also going to replace my fog light switch aswell.
i actually dont find that tell tale light to be in a very good place, since i would never look down there while driving, which makes it kind of pointless.
Thanks Dan, uve been a great help with this
Chris
#21
Posted 10 May 2009 - 08:51 PM
#22
Posted 10 May 2009 - 11:51 PM
Looked a bit odd on such a "modern" car but the owner had it wired as a reverse lamp (I saw it come on
as he negotiated his way out of the car park) and his factory fit reverse lights did not come on.
I thought this was illegal - but are we sure ?
As there is no requirement for reverse lights for the MOT, is there any other legislation about what you may or
may not fit as a reversing lamp ?
I've got one on my boot just because I think it looks a treat. But it's not wired.
But if I find out it's legal as a reversing lamp I'll go for MK1 rear lights and wire it up !
Best wishes
Monty
