sounds like your oil pressure relief valve may be stuck...
It's behind the domed nut on the front of the block, undo, remove spring and you should be able to remove the little thimble valve with your little finger.
If not it's stuck... which will give erratic oil pressure
Its stuck!
How do you get them out?
