What Fuel Pump To Buy?
Posted 21 April 2009 - 07:15 AM
I havent run the car over winter & now it wont start (when the battery is connected & the ignition turned on I can't hear the pump working) so I guess it's goosed!
The orginal electric su items are around £60-70
but there seems to be a large selection of other pumps avalible.
has anyone got any recomendations?
Craig.
Posted 21 April 2009 - 07:55 AM
If that fails then there are copy versions but personally I would move to the solid state Facet pump - the small square one. You would need no more than the fast road version and they don't need any pressure regulation. Basically fit and forget - very good pumps.
Posted 21 April 2009 - 08:04 AM
Does it have an SU pump on it now? If so remove it, take off the bottom and clean up/flick the points a few times - they can usually be persuaded back into action.
Thanks! how about fitting? is there any new mount / holes to drill? is it fitted in the same location as the old pump?
Posted 21 April 2009 - 08:47 AM
Posted 21 April 2009 - 08:57 AM
Posted 21 April 2009 - 10:14 AM
standard mech pump will do the job
But probably not on a car that has an electric pump already fitted and plumbed and therefore may not have a mounting point/hole for a mechanical pump?!
Posted 22 April 2009 - 11:01 AM
I know the standard would probably be ok but with twin 1/2" carbs I thought the fast road pump would suit best!
I'm I right in thinking it will bolt through the existing holes in the rear subframe where the old fuel pump was? or will I have to drill some new?
also bought some rubber mounts & filter
Thanks for the help
Craig.
Posted 22 April 2009 - 11:59 AM
Posted 22 April 2009 - 12:01 PM
I think there is only one hole in the subframe so you'll probably need to add another or fabricate a bracket. I think DKLawson did a similar conversion - PM him for some pics!
there is a small bracket all ready supporting the pump at the moment.
Posted 22 April 2009 - 12:50 PM
There are photos of other people's installs on the following links:
DKL's -
http://home.mindspri...ics/facet05.jpg
Mk1leg's -
http://www.theminifo...x...17&hl=facet
Posted 24 April 2009 - 07:07 AM
I have just read the instructions & it highly recomends instaling an oil pressure regulator (I think) for saftey incase the engine stops.
what do you guys think about this?
Craig.
Posted 25 April 2009 - 06:22 PM
Should I just put the earth lead that comes from the existing cars loom onto the new earth lead on the pump?
Went to B&Q, they want £25 for the smallest cut of steel!!!!
(kind of wish I just bought the direct replacement (would have been easier)lol.
Posted 27 April 2009 - 01:46 PM
Posted 05 May 2009 - 12:07 PM
I'm now thinking that the old unit was ok & the problem lies with the power supply to the pump.
has anyone got any idea's?
thanks
Craig.
Posted 05 May 2009 - 01:17 PM
