Bmw 325i - Not A Mini! (sorry)
Posted 23 April 2009 - 03:17 PM
Problem: loads of travel on the brake pedal, travels 3/4 to the floor then gets firm, but with engine running (servo action) it pretty much gets to the floor feeling spongey. He's had no loss of fluid.
He's got a servo, tandem master cylinder front back split, with ABS, discs all round, aftermarket calipers and steel flexi hoses.
I've checked for leaks on all lines, bled full system, checked calipers for leaks, also had mastercylinder off and servo side is also dry.
I made the assumption one piston wasnt sealing in the master cylinder letting the pedal atleast half way without doing much, swapped master cylinder with one off of a friends car who's brake pedal was high and firm (same car by the way lol).
Problem not resolved.
I've also adjusted out all the slack in the pedal mechanism, so where's the travel coming from?
Thanks in advance.
Posted 23 April 2009 - 03:38 PM
Posted 23 April 2009 - 05:05 PM
No really, it does sound like air in the system, give it a good bleed use a pressure bleed (about £20) and see if this helps
oh and don't worry about my sense of humour
Posted 23 April 2009 - 05:10 PM
Posted 23 April 2009 - 06:00 PM
Posted 23 April 2009 - 06:18 PM
thanks for the replies though, i'll try pressure bleeding
i've not bled a system with ABS before, i've been giving it 13 pumps per corner starting furthest away etc.
what's a dsc modulator? inside abs?
yes i've checked for a leak into the servo.
thanks again
Posted 23 April 2009 - 08:48 PM
Good Luck
Posted 23 April 2009 - 09:01 PM
It could also be possible that the internal walls of the rubber pipes have clapsed, try checking all the rubber pipes to see if they are bulging when the brakes are on?
Posted 23 April 2009 - 09:19 PM
think most of the flexis have been replaced but i'll double check for rubber pipes.
thanks guys, i'll let you know how it goes.
Posted 23 April 2009 - 09:22 PM
The safe way to push the cylinder in on any car is to clamp the flexi hose,undo the bleed nipple push the piston in then do the nipple up again before removing the pipe clamp,you will obviously lose a tiny bit of fluid but you will not damage anything this way.
Posted 23 April 2009 - 09:29 PM
Posted 23 April 2009 - 10:03 PM
Posted 24 April 2009 - 10:37 AM
My Dad's been trying to read up on it, the reason I had the engine running was something to do with getting the abs to activate or something, but I got no warning light or anything.
Apparently you can get gadgets to activate the ABS whilst bleeding?
Cut a long story short, no air bled out of the system.
Boycie I just changed the master cylinder for one that was working nicely on another car.
Any more ideas? Still don't want to send the poor guy to BMW at £90 an hour.
Posted 24 April 2009 - 10:54 AM
You might have got air traped in the abs pump. Try using a pressure bleeder rather than doing it manualy.
If you are going to do this make sure that you wear the correct Personal protection equipment, high pressure fluids can damage your health....
Posted 24 April 2009 - 12:13 PM
