Well I have sorted the windscreen leak but alas I have more leaks.
The leaks are on both doors.
When the car is hosed down I get water running out from between the door trim and the door. For instance on the passenger door when looking from inside the leak is at the bottom left corner where the inner door panel (trim) sits against the door.
I will try and get the panels off this weekend so I can see where its coming from but maybe you guys will say "oh yeah thats common its.............."
Edited by kstadseve, 24 April 2009 - 07:54 PM.
