Cap'n crunch...are you running a 28/36 DCD at the moment?
Yep
and before that i ran Twin HS2 on the exact same engine.
Personally i see it like this
Weber 28/36PRO - Not many people use them so are unique, Once they are set up for your engine that is it no more tuning required, Give both Efficency and Max Power as they are progressive twin choke. Parts are still easy to get hold of. Looks cool. Throttle response is great low down due to the small primary venturi and really pulls when you open up the secondary.
CON - A-series Manifolds are rare as rocking horse manure, needs someone who knows webers to tune it (though most mini/classic car friendly garages or rolling roads are), had to make my own throttle linkage, my particular inlet and exhaust manifold fouled on each other before i had it machined.
Twin SUPRO - more spare parts than you can shake a stick at, good throttle response, v.efficent mini carb and good max power. Good mixture spread between cylinders due to no turns leading in the cylinder head. has the classic mini look and style.
CON - Constant tweaking and do go out of tune, carb icing, If the dashpot oil is to thin or too thick it adversly effects acceleration. Even less space in the engine bay.
I would say Weber every time, as i get better MPG, no carb icing, better response through out the range, No more messing around with the mixture and the idle adjustments, no more changing the daspot oil, the great sound when i get to 4k rpm and open up both chokes.
Max Power wise overall BHP will probably be within 3-5 bhp of each other and the same goes for torque. So either you do not lose or gain in perfomance numbers.
