The min
#16
Posted 27 February 2006 - 05:25 PM
Keep us updated!!!
#17
Posted 28 February 2006 - 07:01 PM
hi, i was just wondering where you got the turbo manifolds? as im thinking of having a go at one myself, 998 i can get a t2 turbo and intercooler and a plenum chamber off a metro turbo, what else will i need? actuator, fuel feeds? cheers
hello mate the metro turbo doesnt have a t2 turbo or an intercooler. to fit the t2 you either need to modify the metro manifold, or get some mirage manifolds. if you use the mirage, you dont need to modify the bulkhead. have a look on turbophils site for info on the turbo conversion.
#18
Posted 05 March 2006 - 12:19 PM
#19
Posted 20 March 2006 - 08:44 PM
been trial fitting the manifolds to an old head, and have managed to get the turbo inlet to fit with the mirage exhaust manifold (after some tweaking with an angle grinder). the flange (heehee) on the inlet was 5mm thicker so this had to be adjusted as well. the pic shows where the manifold has been ground to clear the other one.
and heres the two on together. very little room for spanners etc
Posted 09 September 2006 - 10:03 AM
gotta sort out the rear lights, wipers and horn, then im off for a test drive, which im looking forward to.
#21
Posted 11 September 2006 - 10:53 AM
#22
Posted 11 September 2006 - 03:45 PM
#23
Posted 12 September 2006 - 08:21 PM
minipip, i believe you can get a spanner between the head and the manifold.
the engine now has 11 miles on it, and has had an oil change. it going really nicely, gearbox sounds fantastic, not as loud as i thought it would be. for a low compression ratio (8.0-1) it goes really well
#24
Posted 13 January 2007 - 02:26 PM
when off boost. You still aiming for 130bhp or a bit more?
Nice looking project.
#25
Posted 13 January 2007 - 02:54 PM
not had time to do much lately except collect parts, but ill take it all into work next week and start making brackets etc
i'll go for about 12psi probabaly. i've also decided on a morespeed stage 3 head, which also has bigger valves than standard. this should give over 130bhp i'd have thought. we'll see
Edited by Leonard, 13 January 2007 - 02:56 PM.
#26
Posted 13 January 2007 - 11:48 PM
What intercooler will you be running? When you hoping to have the turbo etc installed?
Have you ordered your head yet?
#27
Posted 14 January 2007 - 08:34 PM
#28
Posted 15 January 2007 - 06:55 PM
things. Im hoping to have mine done in a few months as well then its the boring task of running it in.
How long are you planning on running it in for?
#29
Posted 15 January 2007 - 10:22 PM
#30
Posted 16 January 2007 - 05:23 PM
make sure your cars are spaced a few feet appart or you'l smash into each other with the torque steer haha
