Cant turn the car over, the starter is struggling and with the plugs out its impossible by hand!!!
is my crank ???
thanks
danny
Cant Turn Over?
dannyg2325
, May 01 2009 07:13 PM
5 replies to this topic
Posted 01 May 2009 - 07:13 PM
Posted 02 May 2009 - 09:19 AM
is it a new engine?
if so could just be tight and needs a good strong battery to get it to turn over to run it in
Posted 02 May 2009 - 01:25 PM
no just the heads been worked abit, still have the problem of low compression in cylinder 1. its down with a guy at the minute whos gonna run a few tests. but he said if its that hard to turn over, its possibly the crank.
the bit i dont understand is when the engine was out and the side casing was off, i was fit to turn it over at the crank with a spanner. but no its deadly
Posted 02 May 2009 - 05:49 PM
low commpresstion dosent sound good what do you think that will be?
Posted 02 May 2009 - 09:39 PM
im either thinking its the valves or else the piston rings! 1st run gave us 15psi dry, 2nd run showed 40psi wet, an the 3rd run after a drop of paraffin gave us 60psi. so if its not the head and not the rings, i think things cud get alot worse for me! lol.
Posted 04 May 2009 - 10:09 AM
for ease lets hope its the head, that will mean no rebuild
