I would advise binning the circlips and using piston buttons. I can get these made for around £20 a set.
Cheers, I'll just give them to MED, see what they say, and what they can do.
Posted 21 May 2009 - 04:10 PM
Posted 15 June 2009 - 05:46 PM
Posted 15 June 2009 - 07:21 PM
Posted 15 June 2009 - 07:28 PM
He said the piston crown was 6mm thick, and he measured the dish on a 1293 omega (6cc) and the dish was something like 5.2mm, but because the 998 pistons are a smaller diameter the dish would have to be deeper, therefore wouldn't be possible as the crown is too thin. ??
Please help as we are completely stuck lol.
Thanks.
Posted 15 June 2009 - 07:38 PM
Doens't look good .
Posted 15 June 2009 - 07:41 PM
no it doesn't
Posted 15 June 2009 - 07:42 PM
Posted 15 June 2009 - 07:50 PM
if lowering the comp is your aim why not use pistons as they come and use a 120 thou thick cometic head gasket
although they dont list one for a 998 spoke to these guys last week and they can order a 998 head gasket in any thickness up 120thou thick from the factory in the states
http://www.performan...istributor.html
Posted 15 June 2009 - 08:02 PM
Hmmmm, seems like a way around it, but how reliable would that be? Don't want be changing the head gasket every two weeks lol. Also, wouldn't that be like using a decomp plate? Cheers for the reply STIG .
Edited by THE STIG, 15 June 2009 - 08:10 PM.
Posted 15 June 2009 - 08:07 PM
as reliable as any other head gasket
they make them for allsorts of high performace engines
its the same head gasket that minispeed use on there supercharger kits only theirs is for 1275>1400 cc
no is not the same as using a decompression plate as thats has 4 mating sufaces with the head gaskets ,theses gaskets have 2 as made in one piece ,
Posted 15 June 2009 - 08:21 PM
Hmmmm, very interesting, any idea how much that would lower the compression by?
Posted 15 June 2009 - 08:23 PM
depends on all your other mesurements how many cc in pistons, how many in head , how far dont the bore are the pistons etc
but a 12o thou is enough the run a standard head and piston set up on a 1275 cc superchaged engine
so will be able to get the requried comprssion of 8.1 as can always work head chambers if needed
Posted 15 June 2009 - 09:02 PM
Posted 15 June 2009 - 09:05 PM
looks like quite a good option. Any idea on price?
Posted 15 June 2009 - 09:17 PM
