Water Temperature Sensor
Posted 06 May 2009 - 05:34 PM
Is this. the right item? If so, does anyone know of a cheaper supplier?
Ed
Posted 06 May 2009 - 07:56 PM
Posted 06 May 2009 - 09:42 PM
If you need one and dont want to pay 40 quid i could always try the place i got mine from
Posted 07 May 2009 - 07:06 AM
Posted 07 May 2009 - 11:45 AM
Try to test it first, i thought mine was faulty and £35 quid later it was still not running correctly. You should be able to check the voltage drop from 5v towards 0v as the car warms up but you will need to clip into the correct wire to do this.
Did you clip your Multimeter to the contacts on the bottom of the temp sensor then? Or did you get a feed from elsewhere?
Ed
Posted 07 May 2009 - 12:58 PM
Ed
to be honest didn't know enough at the time to test the mini, tried it on another car(fiesta) and was able to see the voltage drop off as the car warmed up. A scope is much better as it sort of takes a picture and is better for other sensors on the car. if you have a look at the guides in the injection system they are pretty good, sprocket knows his stuff on these systems and has put a lot of good info up there. I would check vac lines etc before i start spending any money.
