Disk Brake Sizes
17 replies to this topic
#1 stewart
stewart
  • 143 posts
Posted 11 May 2009 - 09:27 PM
Im planning on fitting a set of MB's to my mini and need to know whether a pair of 7.9" vented disks and 4 pot calipers will fit behind them? Any-one have any ideas as to whether they will fit?
Cheers stu
#2 mk1leg
mk1leg
  • 9,343 posts
Posted 11 May 2009 - 09:35 PM
You will need 7.5 discs for 10" wheels I have just fitted KAD 4 pots and the only wheel That I managed to fit over them are mini 1100 special's................
I think Minisports are a little smaller so they might do................ =]
#3 MRA
MRA
  • 7,607 posts
Posted 11 May 2009 - 09:53 PM
Working on callipers at the moment that will fit an 8.4" disc behind 10" wheels ...... ok so it won;t work for all 10" wheels, so we have designed it to be easily modified to suit your own wheels =]
Take a look at our 13" kit ;D
Regards Martin
#4 p.park
p.park
  • 217 posts
Posted 12 May 2009 - 02:11 PM
Question!
I have a 1981 austin mini HL Auto, which has a set of standard 10" wheels etc.
I heard from various sources that i have only two options for disc brakes
1. cooper s 7.5" (the whole kit)...costing round £500
2. go up to 12" wheels (+tyres costing £200 or thereabouts) and second hand 8.4" (around £100)...(but then I need the spacers..and probably hi-lo's to adjust the high of the car..etc..)
Which do you think is worth doing?
any alternative....?
like modifying something somewhere so I can have the cheap 8.4" discs on 10" wheels?
#5 p.park
p.park
  • 217 posts
Posted 12 May 2009 - 02:41 PM
http://www.minispare...mp;tc=1#submenu
does this mean i can get disc brakes on my 10"?
#6 MRA
MRA
  • 7,607 posts
Posted 12 May 2009 - 02:43 PM
The kit you mention only fits if you already have the correct hubs... :D
Regards Martin
#7 GraemeC
GraemeC
  • 7,440 posts
That is a conversion kit from 8.4" disc brakes (12" wheels) to 7.5" disc brakes (10" wheels). You need the bigger kit if you are currently on drums.
I have 7.9" discs with KAD 4 pot calipers behind 10"x5" GB alloy wheels with no problems.
#8 p.park
p.park
  • 217 posts
Posted 12 May 2009 - 02:54 PM
so..the 7.9" discs will fit behind my 10x4.5J?
#9 p.park
p.park
  • 217 posts
what mod's do i need doing?
or what kits do i need for my 10" wheels?
#10 p.park
p.park
  • 217 posts
Posted 12 May 2009 - 02:58 PM
Darn!
i think mine's 10x3.5J!!
can any one confirm that (1981 austin HL auto)
does this mean the wheels are too narrow for 7.9" disc fitment??
#11 GraemeC
GraemeC
  • 7,440 posts
Posted 12 May 2009 - 03:17 PM
I take it you mean steel wheels? They may fit - I think KAD have a template on their site somehwere you can print and offer up to you wheel. The width (3.5J) won't make much difference (although the offset might).
To go from drums to 7.9" wheels could prove expensive - you would have to follow your 12" route posted earlier and then get new alloy calipers (from £250/set), have the discs turned down (£20) and get new pads (from £25/set)
To be honest if you are sticking with 3.5" steel wheels and presumably 145r10 tyres then you really don't need anything as fancy as 7.9" brakes. You can sometimes pick the Cooper S 7.5" ones up as a full setwith hubs for around £300 on ebay.
#12 Cooperman
  • 23,325 posts
Posted 12 May 2009 - 07:52 PM
The other alternative is the 998 Cooper disc brake. They are not much better in brake efficiency terms, but they don't need constant adjustment like the drums do and with decent pads are a good compromise.
As the original cooper 997/998 had 3.5 x 10" wheels they fit easily and you don't need the expensive 'S' set-up to fit them.
#13 p.park
p.park
  • 217 posts
Posted 15 May 2009 - 01:48 PM
can any one confirm what cooperman said?
so, all i need to buy are:
a couple of 7" brake discs
brake pads
calipers
and i can just swap?
#14 GraemeC
GraemeC
  • 7,440 posts
Posted 15 May 2009 - 02:06 PM
I think you would still need different hubs too - I doubt the cost would be much less than 'S' discs to buy a secondhand set (if you can find any) and then refurb them.
It is commonly thought that twin leading shoe drums will out perform the 7" cooper discs - they were poor even when they were brand new and 'the latest thing'!
#15 Asphalt
Asphalt
  • 2,173 posts
Posted 15 May 2009 - 02:07 PM
Yes and no... The 7" brake is by far the rarest brake to get hold of, IMO...
I never drove it myself but it is said that they are not better than drums (some insist they are worse :thumbsup:).
To switch from drum to discs you need:
- pair of disc brake hubs
- pair of cooper S drive flanges
- pair of cooper S calipers
- pair of outer disc brake CV joints
- set of pads
- pair of 7.5" discs
- wide/spacered rear drums & longer wheels studs)
- smaler rear brake cylinders
Or... the same parts for a 7" brake (minus spacered drums).
Or... the same parts for a 8.4" brake (+ 12" wheels)
Or... as above if you feel you need four pots and 7.9" discs.
So basicaly you need what's in this kit: http://www.minispare...ty=pb&pid=37121
Most 3.5" wheels should fit the 7.5" S brake, there are however some early ones that don't. It's realy a matter of try & error. But I think yours should fit fine as they are most probably the later ones :)
Edited by Asphalt, 15 May 2009 - 02:08 PM.
