Angry Tractor
23 replies to this topic
#1 Bigfoot
Bigfoot
  • 107 posts
Posted 12 May 2009 - 10:37 PM
1999 Rover Mini MPi
Hey everybody,
I spent today putting my exhaust system back together, I'd dismantled it to sort a snapped manifold/downpipe stud. Everything seemed to go reasonably smoothly, I used new gaskets for the manifold/block, manifold/downpipe and downpipe/cat joints and new studs/nuts for the manifold/downpipe connection.
As far as I can tell I put it all back together as it should be (also installed a K&N filter element) but when I started it up it sounded like two tractors sumo wrestling under the bonnet.
It's running incredibly rough, the usual tailpipe blast is more of a feeble gusty splutter, and I think there was exhaust gas leaking from somewhere around the manifold (looked like it was coming up between the manifold and the heat shield). Didn't have time to investigate as I had to leg it for work.
Can anyone suggest what I may have done wrong? I'd rather it was something stupid and obvious than something complex and expensive :xmas: Really don't fancy going out tomorrow and dismantling it all again.
In short - my exhaust sounds strangled and choked - what on earth's the matter?
Thankyou!
Roy
#2 mars red mike
mars red mike
  • 1,500 posts
Posted 12 May 2009 - 10:43 PM
A t guess id say either the manifold isnt tight enuff against the head or its a bit mis-aligned.
#3 nicksuth
nicksuth
  • 1,631 posts
Posted 12 May 2009 - 10:48 PM
Did you fit the 2 x location rings back in the inlet manifold/head recess? Re-connected ALL sensors (in particular, the Lambda Probe)?
#4 Bigfoot
Bigfoot
  • 107 posts
Posted 12 May 2009 - 10:56 PM
Yup and yup - I can try reattaching the manifold, although it's located by the two end studs, and I tightened it up as much as possible.
Rings are in, and there's no loose connectors flying around, but I'll try disconnecting them all and cleaning them up a bit, in case some dirt got trapped and messed up a connection.
#5 MRA
MRA
  • 7,607 posts
Posted 13 May 2009 - 07:28 AM
And did you put any exhaust paste on any of these gaskets ? as with any vehicle that has a CAT exhaust paste will block it up :xmas:
If its cool, start it up and see if you can feel any escaping gases, br careful though
Regards Martin
#6 Bigfoot
Bigfoot
  • 107 posts
Posted 13 May 2009 - 07:34 AM
Nope, no paste at all (I don't have any :xmas: )
#7 MRA
MRA
  • 7,607 posts
Posted 13 May 2009 - 08:54 AM
Is the head and manifold standard ? and did you use a standard gasket ?
Did it make the "tractor" noise from start up..... or was it ok then gradually started to make the noise ?
Regards Martin
#8 Bigfoot
Bigfoot
  • 107 posts
Posted 13 May 2009 - 09:00 AM
Engine is completely standard, and I used this gasket..
As soon as the engine started, it was up at 2000rpm and sounding like death on a stick, it then drops slowly to about 1000rpm while still sounding strangled. Then I switched it off as it sounded like it might stall.
#9 Bigfoot
Bigfoot
  • 107 posts
Posted 13 May 2009 - 09:03 AM
Aha! Just picking over what might have gone wrong - I put the metal side of the gasket towards the cylinder head. Am I right in thinking this is wrong (heh) and could this contribute to the problem?
Cheers.
edit: Definitely wrong (checked the old gasket), so I'll sort that, but why would that make it run so terrible?
Edited by Bigfoot, 13 May 2009 - 09:21 AM.
#10 nicksuth
nicksuth
  • 1,631 posts
Posted 13 May 2009 - 09:21 AM
Cheers.
Oooops, yes, the metal side goes against the manifold (usually stamped on the gasket "Manifold Side"). I'm afraid your going to have to replace it with a new one as it's probably been damaged (compressed) when you tightened it up?
#11 Bigfoot
Bigfoot
  • 107 posts
Posted 13 May 2009 - 09:24 AM
Shoot shoot shoot - will it definitely need replaced, or would I get away with reusing it? Going to be tricky getting a new one at short notice (ie today).
Thanks.
#12 nicksuth
nicksuth
  • 1,631 posts
Posted 13 May 2009 - 09:30 AM
You could risk it as it's not been on very long and probably not seen too much heat? I've just compared one I took off recently with a new one and while the faces don't look to bad, it's deffinately been compressed (head side) compared to the new one. Give it a go for now and get another one on order!!
Edited by nicksuth, 13 May 2009 - 09:30 AM.
#13 Bigfoot
Bigfoot
  • 107 posts
Posted 13 May 2009 - 09:42 AM
That plan is better than no plan! Just phoning round a load of motor factors first to check.
Cheers :kiss:
#14 MRA
MRA
  • 7,607 posts
Posted 13 May 2009 - 10:16 AM
Firstly is it definately leaking at the manifold ?
Regards Martin
#15 Bigfoot
Bigfoot
  • 107 posts
Posted 13 May 2009 - 10:22 AM
Just away to go investigate further (I've sourced a new gasket, picking it up this afternoon), but when I started it yesterday, I could see some sort of gas/smoke/vapour coming from the manifold area.
I have no idea if it's simply a backwards gasket causing the problem, but I'm going to go change the gasket, clean up all the wiring connectors, put it all bac ktogether again and see what happens when I turn the key.
Best-case scenario: it was the gasket, and everything purrs away happily
Worst-case: it wasn't, and I've damaged something vital
Either way, best way of finding out is to sort it.
