Angry Tractor
23 replies to this topic
#16 brianmini
brianmini
  • 213 posts
  • Local Club: MiniClan
Posted 13 May 2009 - 10:32 AM
If memory serves correct, and this was some years ago, but when i fitted a new manifold gasket (the correct way round, I assume because i've never removed it again), it gave off some fumes/smoke while it bedded in, soon cleared up. But the stench fair burned your nose if you were anywhere near it.
#17 Bigfoot
Bigfoot
  • 107 posts
Posted 13 May 2009 - 10:42 AM
This really isn't running right, though, something in the engine bay is making crazy 'fraaappp ap app ap' noises and it sounds majorly bad.
#18 Bigfoot
Bigfoot
  • 107 posts
Posted 13 May 2009 - 04:13 PM
Argh!
Ok, I went out, I've flipped the gasket over (looked fairly useable), tightened everything up really really tight, connected ALL wiring and plumbing connectors (I might have missed the throttle potentiometer last time) and tried to start the engine.
All I get is a 'chugchugchug' and the engine doesn't catch!
Can anybody suggest what could cause this, and I'll check it out?
I also fitted a new teardrop mount while I was at it, which involved moving the ECU - reckon I might have screwed up there?
Thankyou!
#19 Bigfoot
Bigfoot
  • 107 posts
Posted 13 May 2009 - 07:43 PM
Quick update: As far as I can tell, the fuel pump isn't pumping and I don't think I have a spark. All four fuses next to the ECU are intact, as are all the fuses in the cabin fuse box.
What fault could cause the ECU-related systems to fail but the independent ones (starter, fuel guage, dash etc) to work properly?
Cheers.
#20 nicksuth
nicksuth
  • 1,631 posts
Posted 13 May 2009 - 07:46 PM
Has your inertia switch dropped out? Just press to reset.
#21 Bigfoot
Bigfoot
  • 107 posts
Posted 13 May 2009 - 07:51 PM
I pressed it a few times, at the moment it's in the not-popped up position. Is that good or bad?
PS. Sorry, I'm knackered, not thinking too clearly >_<
#22 Bigfoot
Bigfoot
  • 107 posts
Posted 14 May 2009 - 08:45 AM
Sorry, blatant bump. I really have to get this running by this afternoon, and all I know so far is it'll be an electrical problem, and should have something to do with the ECU/relays, or something along those lines.
Anybody able to shed some light on probable causes?
Starter turns, no fuel pump, no spark.
Thankyou!
#23 powermadcoop
powermadcoop
  • 471 posts
  • Local Club: Minimus Maximus
Posted 14 May 2009 - 11:11 AM
Can you hear the pump priming bit like a "zzzzzzzzzz" noise when you turn on your ignition s your ignition lights come on?
#24 Bigfoot
Bigfoot
  • 107 posts
Posted 14 May 2009 - 11:30 AM
Nope.
