i see
Thanks for the quick reply!
Engine Bay Popping= Fuel Starvation= Cure?
flanders56
, Jun 01 2009 05:41 PM
20 replies to this topic
#16
Posted 01 June 2009 - 08:00 PM
#17
Posted 02 June 2009 - 07:04 AM
Timing - mixture - Needle profile, Idle speed.
That's it?
isn't this something one can do at home with a tachometer and a pair of good ears ?
Needle profile you'd do amazingly well to do with your ears. Essentially going through the throttle range and richening or leaning off the fuel at each point, (think a mini needle generally has ten points), to maximise performance and driveability, and remove any flat spots, it's a lot of work!
Timing, if you get an adjustable dizzy it's possible to modify the advance curve to get the most out of your car.
Dave
#18
Posted 02 June 2009 - 10:53 AM
my worry is that, after all the r/r tuning, if i change anything...i'd be back to square one...
e.g. if i get a new cam shaft...then it would need another session on r/r ?
#19
Posted 02 June 2009 - 11:28 AM
p.park,
Yes! Unfortunately, changing your cam will change the way the engine behaves and a new rr setup will be required
#20
Posted 02 June 2009 - 11:40 AM
For this reason do the changes you want to do in one big go, and then RR it.
Now spend time working on handling, brakes, bodywork etc. and after a year or two go back to engine upgrades and RR again to bring it back to it's peak!
D
D
#21
Posted 03 June 2009 - 05:16 PM
gotcha.
thanks for the answers, again, dave and jonesy!
